Question about Maytag Performa PAV2200
Maytag Performa PAV2000 washing machine fills but will not agitate. This problem started within past 2 weeks. It also shakes and wobbles during some spin cycles, but this has been a longtime problem. I understand both of these problems are common with Maytags. My MAIN questions: 1) Does anyone have a breakdown of average in-home repair costs for these problems? 2) Might a consensus of repair firms and customers lean more toward buying a new washer versus having repairs performed? Thanx, Ken 10/15/2010
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
SOURCE: Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Posted on Dec 31, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
dwrooker
  • 6 Answers
SOURCE: maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Posted on Oct 06, 2009
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
Sep 01, 2009 | Maytag Performa PAV2200
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Maytag PAV2000
Its possible that the machine is not reaching full speed during spin. Check to see if the belt is slipping and that the thrust bearing pulley turns freely. When in the spin cycle the thrust bearing compresses the brake directly above it. If this brake is hanging up even a little the machine cannot reach full speed. The diagram on the right shows the thrust bearing assy. and brake.754307c.gif
Jan 14, 2008 | Maytag Performa PAV2200
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Jan 24, 2007 | Maytag Performa PAV2200
Washing Machines Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
