Question about HP Office Equipment & Supplies
My HP Officejet j4550 All-in-One is not printing .when switched on it feeds the paper half way and stops.when you try to print in says printing but the paper does not move .If the plug is disconnected and reconnected,the paper spill out and a second one feeds half way and stops.causing the printer to freeze.
IB4G2008
  • 3587 Answers
SOURCE: HP Designjet 110 plus nr print/feed problem
hmmm..sounds like a memory overload..shut down machine, let the memory clear, and maybe reinstall the print management software..print queue issues are almost always from overloading the memory for the printer..
on the feeder issue, check for paper caught in tray or path, and clean the rollers too.
check your computers warranty here 4 FREE
Posted on Feb 27, 2008
SOURCE: hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 01, 2008
pagebor
  • 2785 Answers
SOURCE: Paper feed accepts paper but
your printer needs servicing
Posted on Apr 23, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
  • 25 Answers
SOURCE: HP Laser Jet 1020 will not print
Just some things to try...
First thing to do is put the printer CD in the carriage and try to print again. Before you press the print button cancel the CD if the printer CD starts to auto run. This is in case your computer is looking for files it cannot find. Sometimes you get lucky when you try to print and the computer finds and grabs the files you need off of the CD. May not work but always worth a try...
Not sure if you have re-installed lately. If not, you may want to see if your printer CD will do a "repair" on your printer.
Check your printer software find the option to "check for updates". Your drivers may need an update. You may need to go to the HP site for this.
Search the HP site - First find your printer on the site. Then you will find downloads and help for your particular printer.
If your printer has a "Toolbox option" (i.e. troubleshooting) try that. If there is no Toolbox with your software the help option will run you through a troubleshooter.
You may want to uninstall and re-install. If you have spy ware or a virus scanner sometimes these apps. will grab files they think are suspect when it is actually files you need for your computer or say printer. So if you have any apps. like that go to company site or get in touch with them. Ask them how to ensure their software is not interfering with printer drivers etc... or other apps. that may just stop working for no reason.
Hope something works for you
Good Luck!
Posted on Mar 01, 2009
My HP Officejet J4550 is low on ink but still prints. im trying to get the orange light to stop blinking so i can print
Hi
you need to replace your cartridges
in order your printer start working
pls vote us to keep us alive
Nov 16, 2010 | Office Equipment & Supplies
I AM TRYING TO PRINT HEAVY STOCK CHRISTMAS CARDS -
If its heavier than 60 to 105 gsm (16 to 28 lb), then your printer can not take that type.
HP Specifications
Unless there is a manual feed on the back, the paper won't be able to bend well inside of the printer, hence the jam.
Nov 29, 2009 | HP Office Equipment & Supplies
HP Officejet Pro L7580: says load paper/won't print
Go to printer and faxes and cheeck the preferences of your printer cheeck the number of copies and all strange that you will saw.
i hope my advice is helpful.
May 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Started feeding business card stock incorrectly - worked previously
You may need to have a technician adjust your copier or replace the rollers.
May 06, 2009 | Office Equipment & Supplies
HP 1315 paper load and scan problems
I would perform a hard reset of the printer electronics and also reinstall the driver to see if the combination of these two procedures restores proper operation.
Sep 20, 2017 | HP OfficeJet k60xi InkJet Printer
Hp psc 1315 paper jam
2.
3.
4.
5.
6.
7.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper will not feed
My OfficeJet Pro K550 makes sounds like it is getting ready to pick-up the Paper but sounds stops and Printer goes back into the ready mode without printing.
Will you please give me some pointers????
Nov 21, 2007 | HP OfficeJet Pro k550 Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Paper feeding.
Careful 'knocking up' and 'riffling' the sheets before placing in the feed tray will go a long way to to alleviate this one. Getting air between the sheets is the object of the exercise . The cutting packing and wrapping of sheets compresses them. Did you know also that there is a right side and wrong side to copy paper? Look at the side or end of a new pack for the arrow.
Aug 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
64 people viewed this question
Seeker5211
Seeker5211
