Question about Kitchen Ranges
Jenn Air D156W error F0
I have an Jenn air electric cook top. The error F0 comes up on the control panel and keeps beeping. The beeping sounds like a timer going off. I cannot find any error codes in the owners manual. How can I stop this beeping. You can turn it off by pressing cancel and it goes off, but it comes on again after a little while. It's annoying.. please help.. thanks
  • Anonymous Nov 24, 2008
    My granddaughter punched the control panel and it lead to F8 error, once that part was replaced, I got an F0 error within 30 minutes. Can't find the Jennaire parts either.
fridgetech
  • 473 Answers
SOURCE: F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Posted on Nov 09, 2007
Bgillespie
  • 89 Answers
SOURCE: IT WON'T STOP BEEPING!
I hate to say it, but the touchpad or computer board needs to be replaced. VERY expensive...goodluck
Posted on Dec 16, 2007
Tiger509
SOURCE: beeping, f0 reading
Here is the link to fix it:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
Posted on Apr 16, 2008
ginko
  • 19396 Answers
SOURCE: Jenn-Air Range: I am getting an F0 error.
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
Posted on May 29, 2009
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
Hello my JENN AIR Jenn Air JMV8208BAS Microwave won't turn off properly. When it comes to the end of the cooking time it beeps and the vent at the top closes but it keeps making a noise and it is still...
I would first suggest checking the bottom door switch and its mount.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
The full service / installation manual is here.
If it's not a switch issue, you may have a sticking relay on your control board, which can be economically repaired. Details are here.
Oct 15, 2013 | Jenn-Air JMV8208A Microwave Oven
My jenn air s176w-c is not working it continiously beeps and a error code of f0 appears on the screen
Hi
Error code F0 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Mar 28, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Numbers washing off cook top
Try taking the knobs off make sure there is no greese on them put them on news paper and lightly spray with a clear laquer,let dry and give them a second coat.
Hope this helped.Let me know by rating me
For more help go to live chat.
len west
Jan 30, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kitchen Ranges Logo
129 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
