Question about Kodak i40 Path-Through Scanner
Kodak i40 Front loading scan
Just purchased my 2nd Kodak i40 scanner. On the 1st one i could scan through the front using the special document feeder for small credit cards and driver license's. On the one I just bought I cannot get it to scan through the front. Does anybody know anything about this problem. Did Kodak discontinue this feature on the i40's?
Try downloading the latest Firmware for the Kodak i40 Scanner at the following Kodak.com page: http://graphics.kodak.com/docimaging/US/en/Products/Document_Scanners/Desktop/i40_Scanner/Support/Drivers_And_Downloads/i30_and_i40_Scanner_Firmware/index.htm
Follow the instructions carefully, and make sure that the scanner and the PC DO NOT turn off while doing the Firmware update. I recomend connecting both to a UPS with a known good battery while doing this upgrade.
This should install the latest features including the one that enables front feed.
Otaron
Posted on Nov 03, 2008
Vertical line in scanned image
This is because of dust sticking to the glass. Clean with isopropyl alcohol (rubbing alcohol) and dont use solvents. For emergency you can use your after shave but take care only to clean the glass portion!
S. Mohan, Chennai, India
Jul 08, 2009 | Kodak i40 Path-Through Scanner
Error 8 in scanner i40
Error 8 = Face up light check failure.
Check Top Lamp is lighting up and not Flickering.
Check connections to Ballast (Inverter) and Lamp.
Jun 30, 2009 | Kodak i40 Path-Through Scanner
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Check kds.log -this is my massage error when i press scan option at canner kodak i 260 "check KDS log" messge error appears when scan option chosen on i40 Kodak Scanner.
Try Calibration routine. If it fails check optics are clean and not scratched. If it still fails change the lamps.The KDS.log is encrypted and can only be accessed via a license key. This is only Available to Kodak reps or through RTS ltd service calls.
WWW.Responsets.co.uk.
Mar 25, 2009 | Kodak i40 Path-Through Scanner
Kodak i40 Scanner - paper jamming
First clean with a damp cloth, then try Isopropyl Alcohol. Dont use solvents. Check if papers are sticky. Stapled papers are 'sticky' even after removing staples. loosen them if required. Notmally rollers last 200,000 to 250,000 scans
Mar 17, 2009 | Kodak i40 Path-Through Scanner
Scanning problem
May be you have selected multipage option. Then all the pages will be part of the same file, you can view them in 'Windows picture & Fax viwer' You need to page down to see the images. Scan only the first page and check the file size. If this file size and the earlier one are different, then it confirms that you have chosen multipage option!
Aug 26, 2008 | Kodak i40 Path-Through Scanner
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
Scaning documents
Try and alter the contrast settings. If the scanner does not pick up 'data' including folds, you'd blame it for non-performance!
S. Mohan. India
Oct 21, 2006 | Kodak i40 Path-Through Scanner
Kodak i40 Path-Through Scanner Logo
518 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
