Question about Soleus Heating & Cooling
Unit will not cool. We have owned the unit for about 2 years. Use with sparingly. Does the refrigerate need to be replaced? If so, how do we get it done? Mr. Marks
  • burzerko
    burzerko May 11, 2010
    I would need more info before I can direct you.
    Is the outside unit(Condenser) running
    Is the furnace or air handler moving air inside of the house.
    Champion:
  • 254 Answers
First off you need to check the filters inside of the home, if they are dirty replace them. I would also check the condenser outside and see if it has a high pressure reset, this is usually on the smaller of the two copper lines coming from the compressor. It will look like a small valve with a button on the top or it will be in a gray case with a small metal stem that may be pushed in to reset. If the high pressure switch has been tripped most likley the condenser is dirty and it will need cleaned. To do this turn off the disconnect to the condenser, take the case apart to gain access using a garden hose rinse from the inside out thourghly.
Posted on Jun 10, 2008
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
Fourwinds hurricane rv
We are Arcticold refrigeration, we manufacture brand new replacement cooling units for Dometic & Norcold RV fridges. Our cooling units all come standard with install instruction, installation hardware, and a lifetime warranty. Feel free to give us a call to free 1-888-782-6665 I can send you the install instructions by email if you would like to take a look at them. In most cases it takes approximately 2 hours to change the cooling unit. I will also need the model number of Refrigerator you have. Visit ArctiCold Refrigeration We keep it cold for some info. Below is a example of one model of cooling unit we build. It is a Dometic RM2852 shown in the picture. 39ede16a-9d21-4648-ad1c-33f0d0c45ff3.jpg 599bd524-a61c-4c24-afa2-1a1a9c84d92c.jpg
Mar 02, 2014 | Dometic Refrigerators
Ever since I had my Unit model 40QxA10-7/38QPa10-7 SERIAL No 745099/o13363 installed in JAN. 2008 I paid a fortune for service and regas every Year. It was supplied by First Choise Airconditioning Again...
an HVAC cooling system is a seal system. it should only need refrigerant added if the level is low. AND if the level is low, there is a leak. Your service company should locate and repair the leak. My system is 10 years only and have never added refrigerant. If only the outside unit was replaced, the indoor unit may be the issue. good luck.
Aug 05, 2017 | Carrier Heating & Cooling
HP15WS
sounds to me you have a thermistor issue which is basically a thermostat but it is electronic now...should be inside the bin on the side wall somewhere make sure its in contact and clean may need to be replaced
Mar 27, 2012 | Perlick HP15WS Commercial Refrigerator
I have a Dometic 2650 refrigerator in my RV. It is leaking a scent of ammonia and we do not know what is causing this or what is leaking. PLease help immediately .
Shut it off immediately and do not use it. Ammonia is sign of coolant leak, thus cooling unit is leaking/faulty, and as I'm sure you know, ammonia is dangerous to inhale etc. Sorry to say but, it's time for a new fridge, and at very least a cooling unit, but speaking from experience, your better off buying a complete new unit. I've seen many people replace cooling unit to save a few hundred dollars, then end up replacing circuit board, and various other item one after the other down the road. New fridge comes with year or 2 warranty as well.
Sep 29, 2011 | Dometic RM2652 Refrigerator
My Summit FF560L refrigerator is not cooling- it is only one year old
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | Summit Commercial Refrigerators
The Whisperkool 4200 unit is no longer cooling the wine room. The digital display is jumbled and will not reset when unplugged. The fan runs constantly but the wine room is only be cooled to 64 degrees. I...
Version:1.0 StartHTML:0000000149 EndHTML:0000001329 StartFragment:0000000199 EndFragment:0000001295 StartSelection:0000000199 EndSelection:0000001295 All WhisperKOOL units come with a 2 year parts and labor warranty with a 5 year warranty on the compressor. During the warranty period, if the unit fails a replacement unit is sent at no cost to you. If your unit fails after this period we offer a Consumer Care Program to give the customer a chance to get a new unit at a deep discount. In many cases, the failing unit has been misapplied and the correct unit for the installation is sought after during the replacement process. Our customer service department is trained extensively, with live customer service representation with a streamlined process for not only helping with the products, but also assisting in identifying any limitations to the installation or ventilation of the cooling unit.
If a repairing the unit is the decided route, call WhisperKOOL directly at 1-800-343-9463 and parts can be ordered depending on availability. A knowledgeable HVAC Professional should perform any repairs due to the refrigeration system.
Jun 30, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
I have a Dometic Rm 2862 2-way about five years old.
Ammonia smell means cooling unit is done. Just double check on dometic site in case of any recalls that may apply. (dometicusa.com)
May 24, 2010 | Dometic RM2852 Refrigerator
GE TFF22RC Side-by Side refrigerator burning smell and no cooling
Sounds like the compressor has gone out or at least the electricals on it. You can replace the relay if that is all it is but at 26 years I would seriously consider replacement. The newer units are more energy efficient and the insulation in your unit has degraded with the years.
Eric
Sep 18, 2009 | Refrigerators
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Heating & Cooling Logo
374 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
