Question about Umax Astra 1220S Flatbed Scanner
When I try to scan I get an error message saying "there is no scanner connected to your computer"
    Master:
    Sergeant:
  • 381 Answers
You need to use the software provided to scan anything or use ms word to insert the scan
Posted on Oct 15, 2010
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I try to scan I get a message - connect to Twain source but I don't know what they are talking about?
The TWAIN device is the scanner itself. The program seems to be saying it can't see the scanner.
Is this scanner new to your computer?
Have you installed the driver for it?
Which program is giving you the error message?
Apr 12, 2010 | Canon CanoScan 5000F Flatbed Scanner
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
C4200 - says USB not connected when trying to scan
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
Mar 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Umax Astra 1220S Flatbed Scanner Logo
44 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
