Question about Ashly FTX-2001 Amplifier
The ashley ftx 2001 series ll amp turns on, everything lights up but seems to not be sending any sound signal to the speakers what could be the problem?
2 Suggested Answers
SOURCE: Ftx-2001 Ashley amplifier with XR-1two
The XR-1 is a 2 way crossover. Depending on the resistor networks, it can be anywhere from 50hz to 5khz. If the packs are marked 153, It's 750HZ, if they're 103 it's 1.2khz if 104 it's around 120hz and 154, 80 hz.
The hi side amp is ch1 the low side is ch2 The amp can be configured as a subwoofer bridged amp , a subwoofer with full range dual ch. You can't make it into a stereo amp with out the obsolete stereo input pack that replaces the XR-1 crossover
Posted on Oct 26, 2011
Can you replace a stock amp with a after market amp without rewiring speaker 2001 sport track
It depends on whether you have the standard audio system or a premium sound system. The standard system has no factory amplifier, the premium system has a factory amp and some other gimmicks that are hard to interface with. A proper OEM amplifier upgrade will require changing the factory speakers with stronger replacements, as well as adapting the factory head unit output to a signal your new amplifier will like. More often than not, it is more economical and better sounding to just change the factory speakers and run the replacements off your factory system. To drastically improve the sound system, it is more effective to just change everything.
Dec 23, 2014 | 2001 Ford Explorer Sport
Marantz Legacy Series - no sound is getting to speakers from tuner or cassette.
It seams like the amplifer is not working and you are right but it certanly needs to be measured first.
Nov 28, 2013 | Marantz Tr 2242 Sb Legacy Series Pll...
I have a Sony STR-K750 receiver running with a Samsung 50 inch series 6 tv.There is a digital lead running from the Austar receiver to the Sony receiver for sound.I have a Hdmi lead running from the Austar...
Run both audio and video to the tv, then use the tv optical audio out to go back to the receiver. The problem is, when you split the signal, the tv takes longer to decode the hdmi signal =, thus delaying it from the original audio signal.
Aug 06, 2013 | Sony STR-K750P A/V Receiver
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
I have a jbl gt series gt5 a3011 amp light on top comes on but the power light doesnt fuses are good everything seems to be connected right and no sound to speakers .
Run a jumper between the power wire and the remote (disconnect the remote wire from the head unit first). If the amp turns on, you got a blown fuse, or other problem with the remote turn on from the head unit.
Jun 18, 2011 | JBL Car Audio & Video
I have 1set power amp " ashly ftx-2001" . my problem is one of component spoill ( ic ), i want to change the componet, but i can't see the code, the ic position near from white fuse, the ic have...
If the IC doesn't work take it out then you will be able to read it just fine!
All you need is a soldering iron and a desolder tool. I like the solder suckers best for these jobs.
May 01, 2011 | Ashly FTX-2001 Amplifier
I have a 2001 voyager dvd player works but no sound. i also get a lot of white noise from any radio stations i listen to. any suggestions?
Hi Had the same problem with my 2001 Voyager. I decided to replace the factory double din size radio/cd with a Kenwood. The Kenwood poered up but no sound. There was one wire that did not connect from the original radio unit even though I had bought the correct wiring loom to connect the new unit. It turns out that this wire sends a signal to a relay in the fuse box under the bonnet to turn the amp on. This wire does not send 12volts but a signal of some kind. The cure was to take a live direct to the front rh relay and this then powers up the amp and everything works fine. Hope this helps.
Feb 27, 2011 | 2001 Chrysler Voyager
Ftx-2001 Ashley amplifier with XR-1two way crossover. I am trying to connect from my EQ (2-1/4 jacks) into my amplifier, do I connect mt left & right out of my EQ into the balanced input XLR. Not an...
Dec 28, 2010 | Ashly FTX-2001 Amplifier
Speakers have played intermintintly for several
you need to find out if your vech has an amp or not call your dealer and give them the vin# adn they can ck to see if the truck was built with or with out an amp.If the truck has an amp the radio sends low level signals to the amp then the amp amplifies them and sends the signals to the speakers. so if the amp is bad and you replace the radio it still will not sent the signals to the speakers.
Feb 25, 2010 | 2001 Chevrolet Suburban
Hi there, My 50 watt MG series marshall amp keeps making a loud rattling sound when its turned up loud. Any ideas why this is and how i could fix it? Ashley Fields e-mail: ashley_ibanez@yahoo.co.uk
bring spray contact cleaner from radio shack near you and clean volume control for amp while you are moving it forward and backward---do not put your mic in front of your speakers because this will give you more trouble.
Sep 12, 2008 | Audio Players & Recorders
119 people viewed this question
Top Ashly Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ashly Audio Player and Recorder Expert? Answer questions, earn points and help others
