Question about GE JKP15 Electric Single Oven
F8 error on a GE oven, model number JKF (or maybe B) 7860P1BG. How do I fix it.
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: GE lower oven displaying code F8. Clear off does not clear code
Your ERC(clock) has failed. Replace the electronic oven control.
Posted on May 26, 2009
iwillfixforu
  • 619 Answers
SOURCE: JS968SF4SS model gives 'F2' error. Possible
F-2 usually oven sensor shorted or bad. Replace oven sensor an you should be good to go. Hope this helps.
Posted on Feb 14, 2010
espressonist
  • 1711 Answers
SOURCE: Ge double wall oven, model
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Jan 01, 2011
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
GE single electric oven is indicating an f8 display
The F8 in a GE electric oven can be a bad ERC unit, check the following link read some more about the fault codes and "probable" causes: http://www.repairclinic.com/0078.asp. Good luck!
Feb 10, 2010 | GE JKP15 Electric Single Oven
Oven displays F7 error code and does not function
Unplug the Oven, Disconnect the Power Supply and then Turn the Oven Back, say after 30 minutes. If the code still appears it could be either Faulty Touch Pad or Computer.
Now,
To check, Turn OFF the Oven as we did earlier, then remove the Control Panel . Disconnect the Ribbon like Cable from the Touch Pad. Disconnect it from the Computer. Turn the Oven, and if Code appears Replace Computer Unless Replace Touch Pad.
It is a Valid Model Number. You could buy the same from :-
http://www.repairclinic.com/Appliance-Parts?s=t-JT950B0A1BB-%3d%3d
http://www.cashwells.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 20, 2009 | GE Ovens
F8 on Ge JTP27 Whats wrong?
The reason to get F8 is that the component failure that occured within the Electronic Range Control (ERC) effecting temperature processing circuits. Th perfect fix for this problem is to replace Electronic Range Control (ERC).
Sep 04, 2009 | GE JTP27 Electric Double Oven
May 26, 2009 | GE JRP15 Electric Single Oven
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
GE JKP15 Electric Single Oven Logo
46 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
