Question about Panasonic KXTG6444PK - Cordless Phone
Panasonic KX-TG6444PK Help...my caller list suddenly is not working. As usual I push menu-scroll to caller list-select and then none of the soft keys will work...I can't scroll through to see missed calls...the only key that will give a response is the off key. Also, I can't pull up my phonebook by pressing the phonebook key at the top of phone. Finally my visual caller id is not working...the talking caller id is working but the visual name/number is no longer coming up. I'm not sure what happened...it has been this way for the past 2 days...ever since my dh had a conference call using speaker phone on the base. I'm wondering if he pushed something that I'm not figuring out? I have been through the menu and everything that should be on is on.
  • sarahreto Oct 15, 2010
    Hmmmm...it is now working. I unplugged the base and moved it to another room and all functions are now working. Maybe the plug was starting to come out? I would think that the phone wouldn't work at all though.
CORDLESSGURU
  • 106 Answers
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Posted on Feb 19, 2008
SOURCE: KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Posted on Jul 27, 2008
CRTN
  • 716 Answers
SOURCE: Panasonic KX-TG2357 talking caller ID
To turn Talking Caller ID on or off
You can turn Talking Caller ID on or off for the handset and base unit separately. If
this feature is off, the unit will not announce caller names. The factory preset is ON.
Handset Talking Caller ID feature
1 Press [MENU].
2 Scroll to “Talk Caller ID” by pressing [d]
or [B], then press Select.
3 Select “Off” or “On” by pressing [d] or [B].
4 Press Save, then press [OFF].
Also Refer To Page 31 Of Your Owners Manual.
If You Do Not Have The Owners Manual It Can Be Downloaded Here.
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Using Fixya.com
Posted on Jan 08, 2009
SOURCE: UNINTENTIONALLY BLOCKED A REGULAR CALLER
no thanks - found my manual
Posted on Apr 11, 2009
  • 225 Answers
SOURCE: how to turn off talking caller id on panasonic
From the handset press 0*4 then 0 for off or 1 for on, press to end: this turns it on or off at the base unit.
From the handset press 9 then 0 for off or 1 for on, press to end: this turns it on or off at the handset.
Posted on Dec 09, 2010
Just purchased Panasonic model #KX-TGF380 phone system. How do I turn off built in answering message and record my own message
Make sure that none of the handsets are in use. First, record your own message. Press Menu then # 3 0 2 from the base unit or any handset. Menu is the middle soft key below the LCD screen on the base unit. It's the right soft key below the LCD screen on the handsets. The # key is below the 9. Use the Up/Down arrows to highlight Yes and then press Select. See the screen for the appropriate soft key. After the beep, speak your message while you are 20 cm (8 inches) from the microphone on the handset or base unit. Press Stop when finished. (The phone will stop recording if your message is 2 minutes long.) Press Exit on the base or Off on the handset to leave the menu system.
Turn on the answering machine. Press the button with cassette tape symbol on the base. Press Menu # 3 2 7 on the handset. Your greeting should be heard by incoming callers unless the unit is set to Greeting Only or the memory is full. To check this, press Menu # 3 0 5 . Again, use the up/down arrows to highlight your choice. Press the appropriate soft key to Save the setting.
If you do not want to use the numbers, you can use the Up/Down arrows and Select. Press Menu, highlight Answering Device. Then highlight Greeting. Then select Record Greeting for the first step.
These steps are available in the manual. All except for the greeting length are on page 57. The last section is on page 63. This is available from the product site: http://shop.panasonic.com/cordless-corded-telephones/corded-telephones/KX-TGF38.html#q=KX-TGF380&start=1 . Click on the Support tab. The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tgf380_en_om.pdf .
I hope this helps.
Jan 13, 2017 | Panasonic Lands Phones
We bought KX-TG4024 cordless telephones. Can the ring tone be changed?
I have a similar model and the ring tone can be changed.
To change on the Handset
1, Press Menu
2, Scroll using arrow up/down key- go to "Ringer setting" then press soft key Select.
3, Scroll to "Incoming call" then press soft key Select
4, You can scroll to "ON/OFF or 2".. Maybe your phone has more choices. Number 2 will be a different ring tone.
5, Press soft key "Save" then press OFF key.
The Base Unit
1, Press Menu
2, Scroll using up/down arrow keys to "Initial setting" press soft key Select
3, Srcoll to "Set base unit" press soft key Select
4, Scroll to "Incoming call" press soft key Select
5, select ON/OFF or 2 with arrow keys
6, Press soft key "Save" then press OFF key.
I hope this has been helpful..
Aug 29, 2011 | Panasonic Cell Phones
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
Panasonic KX-TG2235B KXTG2235 Cordless Speakerphone with Talking Caller ID how to stop it
Press MENU button, scroll to Talk Caller ID by pressing up or down arrow keys, then press Select. Choose off or on by pressing the up or down arrow keys, press Save then press OFF to end
Talking Caller ID is covered on page 14 of the manual. The following link is for a download of the manual in pdf format.
http://service.us.panasonic.com/OPERMANPDF/KXTG2235B.PDF?cm_sp=Support-Operating Instructions-_-Model-KX-TG2235B-_-KX-TG2235B Operating Instructions (English)
Feb 01, 2011 | Panasonic KX-TG2235B KXTG2235 Cordless...
Our visual call waiting no longer works on our Panasonic KX-TGA242CB phones. Our children have obviously pressed the right combination of buttons to disable it and we don't know how to reset it. The phone...
I think if you press MENU, scroll down to "Initial Setting", hit select, scroll down to "Set tel line", hit select, then scroll down to "C.WTG options", hit select, and change it to "on", it should fix your problem. I can't think of another reason why it wouldn't work, but you need to have both Call Waiting and Caller ID. Hope this fixes your problem!
Jun 09, 2009 | Panasonic Lands Phones
Talking caller ID Want to turn it off on base unit!!
You have to press "Menu" "#" then 1 6 2.
You can also just press menu and then scroll to talking caller id, select it and then choose to turn it off. Be sure to press "save" or the your choice will not be saved.
May 17, 2009 | Panasonic KX-TG1033S Cordless Phone
My problem is i had purchased a panasonic 5.8 DIGITAL TALKING CALLER ID I WANT THE TALKING ID TO STOP IMMEDIATEDLY. IT IS ANNOYING THE HECK OUT OF ME
Page 25 of the owners manual says you can turn off talking caller id separately for the handset and base unit. For the handset, press [MENU], scroll to "Talk Caller ID" by pressing the down or up arrows, then press Select, then select "off" or "on", then press Save, then Off.
For the Handset, press [MENU], then scrol to "Initial setting", then press Select. Scroll to "Set base unit", press Select. Scroll to "Talk Caller ID", then press Select. Select "Off" or "On" by pressing up or down arrows.
Jan 13, 2009 | Panasonic KX-TG2336-S Phone
RE: Model #kx-tga931t telephone Panasonic brand
Press: menu scroll down to talking caller id press select scroll down once till you see "off" press select You have to do this on each handset
Dec 21, 2008 | Panasonic KX-TG5583 Trio Cordless Phone
1 Press [MENU].
Oct 10, 2008 | Panasonic KX-TG2357 Cordless Phone
Panasonic KXTG6444PK - Cordless Phone Logo
83 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
