Question about Toshiba 57H82 57" Rear Projection Television
No picture received a 57h82, as it stoped working for owner. When plugged in, red light stays on( I think the standby power light). If you press the on/off button, it makes a clicking sound, and red light goes out. No picture on screen. Help. and Thanks -Roger
  • menasan Jun 09, 2008
    i have the same problem. i had a repair man come to look at it and he said he needed do it in his shop. he said he is guessing around 500 bucks to repair. i didnt commit yet.
  • jsamson1023 Jun 28, 2008
    My tv was working fine then I turned it off for about an hour and turned it back on picture was white with a little color then gone. Sound still works but i get zero video, when I change inputs, volume, channel or anything else. Similar problem 2 years ago the shop replaced a 2 amp pico fuse and it worked. Does this sound like a viable solution and does any one have a service manual I can get emailed to jsamson1023@hotmail.com?
    Thanks.
  • 47 Answers
I would look first to STKs and the 5 amp fuses. There is also a bulletin at repairworld.com and splodeman.com.
Craig www.classtorations.com
Posted on Jun 08, 2008
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
Hi! My digital box - Matsui DTR-2 has stopped turning on from standby. The red standby light is on, but when I press the on/off button on the remote, the function light only flickers and the standby light...
Initially and assuming there was a momentary power interruption, this it is possible that the system has just a glitch and all it needs is a reset. Unplug from the mains for an hours or so to dissipate any residual power and thereafter try again.
Should this be not corrective, then it is possible that the unit has sustained a hardware fault and therefore would require opening up. Further, it needs familiarity with electronic components and circuitry, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable doing a DIY, then perhaps your best bet would be to call it in for service.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 06, 2008 | Televison & Video
Power light comes on but no picture at all...
There are several more fuses in the TV, but they are not like the main power fuse. Most of of the time there black with and lead coming out of each end about the size of a resistor. I think there are 9 of them, you will need an ohm meter to check them and a soldering iron to replace them. Good luck Eric.
Jun 01, 2010 | Toshiba 57H82 57" Rear Projection...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
It keeps flashing between flashing lights regards
Hi.
The TV stays in standby because protection circuit kicked in.
Protection kicks in when an internal fault had been detected.
In your case the SCART cable may have caused a short.
When on protection the TV will stay in standby, will not respond to buttons or remote, and will not start up.
All higher voltages from PSU get shut down by controller board, and only the +5V remains on.
To attempt resetting the TV, disconnect all video cables, disconnect the power cord, wait about one hour and plug it back.
If TV does not restart, then there may be an internal fault.
In that case leave TV unplugged for longer, just in case.
If still no luck, then call Sony to discuss a repair. The number is listed on your owner manual.
If instead TV will restart, do not use the faulty video cable again, this can damage your TV.
Regards
Nov 06, 2009 | Sony Televison & Video
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
I am working on this tv it has no picture and there is a red light blinking
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 06, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
