Question about Acer AL1715 17" LCD Monitor
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new cable and to solder the connector. But I do not know witch cable to connect to witch pin. I am using a standard 15 pin VGA cable (VESA DDC2). The red, blue and green video cables and their corresponding ground cables I can recognize, but the remaining 7 cables I don not know. I have tried to find a scheme on internet but without any success. It has to be costless because I don?t know if the monitor works properly. Gretaings from Jan-Peter in Sweden.
    Master:
    Sergeant:
  • 381 Answers
You have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Posted on Oct 15, 2010
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
http://www.manualslib.com/manual/268264/Acer-S201hl.html#manual
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Acer al2216w problem
wronge connection check it
May 01, 2010 | Acer AL2216W LCD Monitor
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
Sep 02, 2009 | Dell Dimension 3100 PC Desktop
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
Data Cable cut on ACER AL1715sm
Hi, I have AL1716 so pretty the same - both cables (power and analog VGA cable) are inserted into sockets, probably your VGA cable can be screwed in - just unscrew it and go to nearest PC shop to buy new one. What a good cops you have !!
Oct 14, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715s
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 20, 2007 | Acer AL1715s (Silver) 17" LCD Monitor
Acer AL1715 17" LCD Monitor Logo
327 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
