Question about Evenflo Exersaucer Triple Fun Active Learning Center
I don't know what type saucer we have and there are 6 set of humbers on the bottom of product. I took the seat apart and in side were six plastic bar things with 5 plastic marbels. I been trying to get the seat put back together could you please help me, I'll put the numbers in see if that help locate it 5407246, 0355939, 0369685, 0374896,0374892...if you could also include the price of just buying a new seat just maybe cheaper to do that. thank you galsup@hotmail.com
  • 32 Answers
This is the link to request an Evenflo instruction manual and replacement parts: https://plweb.evenflo.com/replacement_parts.aspx
Posted on Oct 15, 2010
Rethreading 5-point harness
Hi Tamara,
We'd have to advise you to contact Dorel USA for further assistance. You can e-mail direct to crelations@djgusa.com
On the back of the carseat shell you will find an orange and white sticker. Take a photo of this sticker and attach it to the e-mail as it will help the customer care advisors to determine which carseat model you have.
Jun 23, 2013 | Dorel Juvenile Group 22741 ATI Convertible...
I took my juicer apart and now I am trying to re assemble it but I don't know where the springs go. Please help
they attach to each side of the metal bar. i threw the springs away because i couldn't figure out where they went, and now the unit shakes like crazy :) but i read up on it and found out the springs go on each side of the bar i think. 50 bucks will replace the bottom part of the machine (base and motor) https://www.unitycart.com/pjss/parts/parts_classic.asp
Jul 26, 2011 | Jack Lalanne Power Juicer 250 Watts
Hi, my samsung r60+ boots up but the screen is dead. A friend tried and connected it to another monitor and it was fine but now not even that works. I know how to disassemble it and have done it (I just...
The Lcd will be connect by two sets of cables/wires. One will be a round type normally a power lead the other is a Flat ribbon cable type. for the flat cable trac it back to the main board and you should should one of two types of clips either a flit bar type , which you would gently and evenly lift , this would be blank normally or beige, or two button sliders on either side of the ribbon cable you would gently slide away from the main seating.
Aside from the screws for the frame normally two on back, one on each side and multiple on top panel.
once off you can gently crack the lcd casing , look for screws under the rubber dots if you have them else most likely a snap apart.
Jul 24, 2011 | Computers & Internet
The front passenger seatbelt is twisted and won' t retract on my 2004 Sienna minivan. How can I fix it myself?
OK - So I have a 2004 Sienna and the drivers seat had a twisted seat belt. To make matters worse it was fully extended and I could not straighten it. Here are the steps I took to get it corrected.
I took off the handle to the sliding door. There are 2 small panels on the handle that can gently be removed with a flat head screwdriver. Once exposed you will see 2 torx bolts. If you have that tool, great. If not you can use a small flat head to unscrew the bolts. This removes the handle
Next use your flat head screwdriver to 'pop' off the bottom center section of plastic (the piece that has the auto door button). The side closest to the sliding door will have a plastic 'snap' that will come out and that will allow enough room to get to the other plastic snap...these come out easily but be careful they don't drop to the bottom. Once unsnapped you will have access to the top plastic center section (where the seat belt is located)
There is another plastic 'snap' close to the sliding door. Unfastening this side will allow enough space for you to access the drivers side and use a 10mm socket to remove the bolt holding that in place. Once out I was able to get both hands on the seat belt & it was easily corrected.
I adjusted the slide to its highest position since that is the way the passenger side is and we have never had an issue with that side.
Put all pieces back in reverse order & you are done. Took about 15 minutes.
Hope this helps.
Oct 06, 2010 | 2004 Toyota Sienna
HP Pavillion DV5 laptop - broken zif connector
Well I do fixing small things like that, no need to replace the whole main board. The problem is I live in Indonesia.
Apr 11, 2010 | Computers & Internet
I took the seat apart to wash and am not sure how to put it back together.
Look for the product number and manufacture date on the side or bottom of the carseat. The instructions then can be found on the Cosco website:
http://www.coscojuvenile.com/usa/eng/Instructions
Good Luck!
Dec 31, 2009 | Cosco Baby Gear
I took carseat apart how do I put it back together?
go on your products website type in make and model and an instruction manual will be available to read or download
Sep 12, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
Removing a discovery 1 head rest the handle type
The headrest is hold by the two bars of the middle. The bars are engaged in two plastic guides fitted in the seat frame. The bars are locked by two little springs located in theses guides. They are very difficult to remove under the seat foam. The solution I used is a hammer (quite heavy) with a T bar from a sockets set . The diameter was exactly the same as the inner diameter of the plastic guide . Then I inserted this bar at the bottom end of the plastic guides and I hit the bottom of the mettalic bars with these tools and I managed. After the inspection, the springs were bended and I had to give the former shape they had before the removal.
Good luck ( sorry for my poor english but I'm french!)
Apr 01, 2009 | 1995 Land Rover Discovery
Need help with putting straps back on
I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
Oct 15, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Model 22-862-wby
theres a steel rod holding the seat to the base. you have to remove it by pushing from the left and pressing the plastic tab on the right. Once the rod is removed the seat comes off the base. To take the cover off press the plastic inserts through which the belt passes from the other sides using a plier. Two of them are at the back and two at the bottom. Once this is done remove the elastic strings holding the cover to the seat and remove the belts.
Oct 16, 2007 | Eddie Bauer Deluxe High Back Booster...
Evenflo Exersaucer Triple Fun Active Learning Center Logo
371 people viewed this question
Top Evenflo Toys Experts
ka4iup
ka4iup
john h
Bill Boyd
Are you an Evenflo Toy Expert? Answer questions, earn points and help others
