Question about HP Pavilion dv6000z Notebook
While using my laptop, the machine started making a sudden clicking noise so I closed the notebook. Then when I opened it again the blue lights indicated that it was on but nothing showed up on the screen. I have turned it on and off multiple times using the power button, with and without the charger cable plugged it. This was yesterday, and the screen still won't turn on.
  • desiree369 Oct 15, 2010
    Well thanks for the help, I went to unscrew the hard drive but decided to take out and then return the battery instead and that ended up working! But I hope there aren't issues with my hard drive...
    Scholar:
  • 85 Answers
This could be a bad hard drive (probably, based on the clicking sounds). Hopefully, it is still under warranty and you can send it back to HP for repair. If not, you can have a new hard drive installed for less than buying a new PC.
Posted on Oct 15, 2010
    President:
  • 2,653 Answers
Try booting the computer with the hard drive removed. You can remove the drive from the bottom of the laptop, you'll see a hard drive icon with two screws on a panel.
What happens when you boot with the drive out?
Logitech QuickCam Deluxe for Notebooks webcam immediatelly shuts down my Compaq laptop as soon as it's plugged into the USB port.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 26, 2013 | Logitech QuickCam Deluxe for Notebooks
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Backlight suddenly disapears.
Sounds like it could be a loose connection to the backlight. This can happen with the opening and closing of the machine over time. The only way to check is to open the case and possibly remove the screen in order to check the connections. It could also be that the backlight is starting to fail. This is not a serviceable part and would have to be replaced.
Jan 20, 2013 | HP OmniBook XE3 Notebook
Hi im tony, i had bought a dell inspiron 1545 laptop 6 months ago and while i was using it yesterday suddenly many windows started open as google chrome crashed i supposed , and it got stuck completely...
In first place you still have the dell warranty because you have use the notebook for only 6 month, but the explanation that states indicates that your machine has a virus, I suggest to take the machine to a rapair shop. Good luck
Dec 06, 2010 | Dell Inspiron 1545 Notebook
Can't type: hello folks... my Dell 630m won't let me type or click unless I am holding the shift key. When I turn it on the machine makes a beeping noise (sometimes one beep, sometimes 20 ) before Ubuntu...
Sounds like a bad keyboard.
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 20, 2010 | Dell Inspiron 630M Notebook
HP built-in wireless internet light cannot be
try this...
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 03, 2009 | HP Pavilion dv9000z Notebook
The screen on my Lattitude 120L won't come on after I close it
goto control panel click on DISPLAY then screensave then POWER SETTINGS and on the left side there is a section called what to do when i close my lid click on that and for lid settings click on do nothing so after u close ur lid it wont disable ur screen
email me at dragonslair2@hotmail.com
names mark
Jul 18, 2009 | Dell Latitude 120L Notebook
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
HP Pavilion dv6000z Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
