Question about Denon DN-2100F CD Player
Denon DN-2100F CD Player Both CD players will not go into a play mode. Cue lamp "On" both channels. Control & Time not active.
robotek
  • 1512 Answers
SOURCE: DENON DN-C615 DISPLAYS "SERVO ON"
The owners manual references turning the servo on and off on page 8
mpro
.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
Posted on Feb 12, 2008
SOURCE: Denon DN-951FA
this may be due to the fault in the head that check the cd , better clean it by using head cleaner , clean the lens in the head i hope this will help you
Posted on Jun 21, 2008
Benimur
  • 6966 Answers
Barring any other hardware problem, this could be indicative of a dirty lens/optical reader. initial corrective procedure calls for cleaning of the lens with a CD cleaner normally used for CD ROM Drives. They are readily available from most computer parts stores. in some instances, it may be necessary to open the unit up and perform manual cleaning using cotton buds, a can of compressed air. Should you venture the manual cleaning, it may also be worth your while to cleaned the guide rails and the other moving parts and re-apply appropriate lubricant.
In some worst case scenarios, it may be necessary to re-calibrate/align the optics or altogether do a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
  • 17 Answers
SOURCE: Denon DN-S3500
Sounds like it may need a motor calibration. You would have to seek out an authorized service center to this adjustment done. It's a quick and easy fix though.
Posted on Mar 10, 2009
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Mar 22, 2013 | Denon DN-C635 CD Player
Mp3 files on the dn hd2500 not recognised by music manager
verify the format of the mp3 files. it must be 2 channel 44100khz to be compatible with dn hd2500!!
Apr 23, 2010 | Denon DN-HD2500 MP3 Player
Denon DN-HS5500 Cue Slip
Try changing the platter speed from 33rpm to 45 rpm The menu for this should be in the preset section on the player.... Good Luck
Oct 06, 2009 | Denon DN-HS5500 Turntable
Switch bwtn CONT or SINGLE play on Denon's DN-C615
Try this:
1. While holding "Title", Press Stop to enter what Denon calls "presetting" mode.
2. Press Track Search Reverse or Track Search Forward until you get to 20, which is the presetting mode for Single/Continuous Play.
3. Press Play to toggle between Continuous and Single Play.
4. Press Stop to exit Presetting Mode.
Hope this works! I just finished a belabored job without Single Play on this unit. I have been searching for the answer too. I don't have access to the deck to try it, but I think this will do the job.
Dec 23, 2008 | Denon DN-C615 CD Player
Denon DN-951FA
Push your "track selector knob" IN towards the unit and hold it in while pressing and releasing your STDBY/CUE button. This resets the microprocessor (kinda like rebooting) the unit. If you want to speak to me further about your 951fa, email me at chris at cueblip dot com Thanks!
May 04, 2007 | Denon DN-951FA CD Player
95 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
