Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
Hi! Bernie here, I have an Linksys E1000 wireless-n router. How could I adjust the interference on my phone (Vtech 2.4ghz) is there an adjustment to make on the router itself or do I have to buy another phone higher like 5.ghz or 6 ghz. I've tried unplugging the phone apparatus etc....then plug in back in. Move to another location etc... So, what is the solution? Bernie PS Could I change the band on the E1000 router?
  • 2,260 Answers
E1000 router is not a dual band router.
It works only on 2.4 GHZ wireless signal.
You can try changine the wireless channel on the router.
If you have installed the Cisco conect software on your computer, then open the Cisco connect software. Go to router settings. Click on advanced settings. It will open the setup page of the router. Go to wireless tab.
Set the configuration view to Manual.
change the channel to 11. See if that works.
If not then change the channel to 1 and check it.
Click Here for more information about the routers and network
Posted on Oct 15, 2010
    Problem Solver:
  • 7 Answers
Most newer phones use channel hopping (jumping from frequency-frequency) to eliminate noise (thats probably why most newer phones don't have a method of changing the channel :grin:)
Chances are it is not the phone causing the problem but a crowded channel by default linksys is on channel 6 (g/b 2.4Ghz) login to the router and try a couple other frequencies (if you have an N adapter in the PC you could possibly get better connection by tweaking the N radio features in the router)
Wireless
Hi, this happens when the router and the phone is running on different frequency. Try adjusting the frequency setting in your router.
May 23, 2013 | Linksys WAG160N Wireless Router
When I try and install my E1000 linksys router it causes the phone line (dial tone) to disappear. Also it doesn't have PPPOA as a protocol option. Also the linksys setup software says that it is n
Don't you require an RJ-11 for a phone line, cause I don't see one on this model? In any case, the ATM protocol should be handled by the ISP modem, and the router should just pick up the established network over Ethernet.
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done. Some models come with a setup disc, but not absolutely required.
http://homedownloads.cisco.com/downloads/userguide/E1000_V10_UG_USA_NC-WEB,0.pdf
Nov 22, 2012 | Cisco Linksys E1000 WirelessN Broadband...
How do i change channels on my router
You change the channel in the router's wireless setting.
This does not give you a stronger signal BUT you can select a different channel so you do not get interference with other wireless routers in your area that are broadcasting on the same channel.
Oct 15, 2012 | Cisco Linksys E1000 WirelessN Broadband...
How can i bost the signel on a linlsys E1000
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.
Feb 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Manual for linksys e1000 how do I connect router to my compuyer?
You can either connect an Ethernet cable from the router to the built-in Ethernet jack that most machines have OR you can install a wireless (Wifi) adapter in your computer and follow the instructions to set up a wireless network...
May 11, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My linksys e1000 router works wirelessly with all my computers except my laptop which uses windows vista SP2, my network card is atheros ar5007, and my ISP is COX. I understand that the network driver is...
Most of the times you would be right when you say its a driver issue. :)
But there are certainly few steps that you can try as in -
a) Making an other third party program manage wireless on your XP SP2 machine
b) Tweaking the wireless channels to check if there is interference(this must have minimal impact as you already state that its working with everything else).
Try downloading a third part freeware to manage your wireless connections and uninstall the arheros client.
But before doing this try with windows client as well.
What is make and manufacturer of the XPSP2 machine??
Sam
Mar 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do i change wifi name on linksys E1000
under the wireless tab there is a setting called ssid thats the name of your wireless router just change its name
What do I do if I forgot my password?
Type 192.168.1.1 on the address bar of your web browser
Now you will be prompted for login details.
Enter login details of Wireless N Router
User Name: (it should be blank)
Password : admin
After entering the details click OK. Now you will be in on the web based setup page of Linksys E1000 Wireless N Router. Click on wireless tab on top as shown in the picture tgere you would see your password.
Hope this helps you.
Dec 26, 2010 | Cisco Linksys E1000 WirelessN Broadband...
I have nt been able to connect the new router HELP
Reset your router to factory, and install software from scratch... I need more details to help you more then this?
http://homesupport.cisco.com/en-us/wireless/linksys/E1000
Dec 22, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
1,300 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
