Question about Dell 926 All-In-One InkJet Printer
Why is my printer only printing color and not black ink while there is a black ink cartridge installed? When I looked at the printer after printing the alignment page, it said alignment problem but there is no solution to this on the owners manual. I checked the ink cartridge and it is securely installed so I don't know what else to do.
    Scholar:
  • 85 Answers
This happened to me as well. Take your alignment page (or print another one) and put it in your scanner. The AIO printer will use the scanned alignment page to reconfigure your alignment.
Posted on Oct 15, 2010
Installing only one printer cartridge
suggest you install a color cartridge and set up the printer for color. When the color cartridge runs out of ink, you should be able to continue printing in black only.
Mar 19, 2010 | HP PSC 750 All-In-One InkJet Printer
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
When I want to print using the photo or black ink cartridges, my printer uses the tricolour cartridge. If I take the tri colour cartridge out, the printer alerts that there is a cartridge missing and still...
If what you are trying to print is a black in white image then you cant print that when you dont have the other colors installed. The reason is because your image/photo has shades of gray, and for the printer to produce gray, it needs the other colors as well. It needs colors to get the light black or gray shades of the photo....
If however, you are trying to print text only, the printer should be using the black cartridge and not the other colors... I believe that there should be an option in the printers preferences to select black ink only... look for it under advance tab...
hope this helps
Sep 05, 2008 | HP Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Lexmark z1300 printer - one cartridge
if you look at the options in the printer there should be an option to use the color cartridge to print black. How does this work? Well what the printer will do is mix all three colors to make a light black. This will eat up your color cartridge faster but is useful when you are out of black ink and you need to print
Apr 23, 2008 | Lexmark Z1300 InkJet Photo Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Dell 926 All-In-One InkJet Printer Logo
207 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
