Question about LG Flatron L1710S 17" LCD Monitor
LG Flatron L1710S Monitor stuck in Power Save Mode
My PC powers up okay but my monitor light remains amber until I press the on/off button which then goes green but after a few seconds goes amber again and shows Power Save Mode. I've tried the escape key on my keyboard as well as the Wake Up key and Power key but nothing happens. Can you suggest anything? From Jim
  • 88JIMP88 Jun 03, 2008
    Thanks, I did try this but to no effect. However, I have fixed it. I think it may indeed have been to do with the cable. I changed the monitor for another and checked the power settings, all of which were set not to go to sleep mode - so not that. I then changed back to my old monitor but wih the newer cable and it worked, after a reboot. I then tried the old cable again and it worked also. So, it may in fact have been a cable problem but perhaps at the PC end rather than the monitor end. So, thanks for the advice which caused me to focus on the cable.
  • 458 Answers
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Posted on Jun 02, 2008
When i switch on the computer, the only thing that appears on the screen is "power save mode on". i have checked all the cables, i changed monitors, but no solution for the moment thanks for...
Im assuming the monitor worked OK until now. The two things I can think of is, First is the cable from the monitor to the computer is either not connected tight either on the monitor side or the computer. The second thing I can think of is a bad video card. I think the monitor is ok because your getting the power save mode on the screen.
I hope this helps you out, if it does please leave me some positive feedback.
Apr 04, 2011 | LG Flatron L1710S 17" LCD Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Can not turn on power save mode
san_pesca, Could be unit is not in power-save-mode, but has CCFL blacklight failure!! But that's only a guess! NO previous history was given or approximate total "ON" hrs. of use unit has seen during it's life!
12fixlouie
Nov 25, 2009 | LG Flatron L1710S 17" LCD Monitor
Have an lg l1710s monitor turn on computer the
YES, You too, bigbill1223, will need to do some soldering of poor thermally fractured solder joints and/or replace some bad electrolytic filter capacitors on your l1710's "switch-mode-power-supply"/ "inverter supply inside the monitor. Visit youtube for "lcd monitor repair""lcd monitor disassembly" videos. You will be impressed with what you find there!!! also visit www.ccl-la.com/badcaps.htm amd www.lcdparts.net and www.badcaps.net for all the info you might need to effect a repair. If soldering ain't your thing, then you will pay 10x the cost of parts alone to farm out the work!! There, I got you started. Now all you need is to do some reading of my profile 12fixlouie aka louie12fix on fixya or another guy that's real good nickname= "buddymc" on fixya. Then do a new comment to your original post. Bye for now. 12fixlouie nrt of windy-city
Nov 12, 2009 | LG Flatron L1710S 17" LCD Monitor
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
LG Flatron problem
i get a black screen and an orange light in my lg lcd flatron whenever i turn it on.. i cnt use my pc because of this problem.. i hope u would answer my question...
u can email me at jmaonir@yahoo.com
tnx man :)
Apr 09, 2008 | LG Flatron L1710S 17" LCD Monitor
LG Flatron monitor remains in Power Saving Mode
Sounds like an issue with a memory card or pci card not properly in place. Try opening up the sytem, then make sure each card is properly inputted in it's slot. This may cause the the monitor to show power saving mode especially if the memory is not properly placed.
Thanks
Nov 21, 2007 | Computers & Internet
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron L1710S 17" LCD Monitor Logo
621 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
