Question about Mi T M WP-2700-4MHB Pressure Washer
What type of gas does it take - Mi T M WP-2700-4MHB Pressure Washer
Is this a big power washer as shown in the photograph?
Is there a separate place to put oil for engine and pump?
If your engine has a place to put oil, then the engine takes ordinary gasoline
If you have a small engine like a weed-eater or chain-saw, and there is not a separate reservoir for oil, then you mix 2-cycle engine oil with the gas in a 40:1 ratio
Pressure washer oil:
Pump fills about half-way up with SAE20 or SAE30 non-detergent motor oil
Engine fills half way up dipstick with 10-W-30 motor oil
Posted on Oct 15, 2010
Looking for Intertherm MGH-075-ABWN-05 gas valve Model 36c67 type 177
WHITE-RODGERS Type 36C67 - Emerson
www.emersonclimate.com/Documents/White-Rodgers/instruction.../0037-5838.pdf
Type 36C67 complete gas control combines into a single compact package the functions of 3-position Gas ****, pressure regulator, 100% shut-off automatio pilot, main operator and Natural-LP Gas Selector. Termostat Circuit Current (24 V Model):. 0.23 Amps. Pilot Gas Outlet: Located at outlet end of the valve. Type of Gas:.
Need refurbished gas valve & tube - mobilehomerepair.com
https://www.mobilehomerepair.com > ... > Nordyne Service & Repair Feb 9, 2014 - The gas valve model is 36C67 Type177 part# is 6243700 ... Two are a electric oil radiator type & the other two are electric grid type. ... guys that you had to rebuild for me hoping it would solve my Intertherm model MGH-055-ABW36C67 gas furnace not heating up hot enough but did not resolve the problem.
36C67-175 - Hvac Controls - Amazon.com
https://www.amazon.com/Unknown-36C67-175/dp/B003WZWGDE Rating: 4.3 - ‎4 reviews
Product description. Robertshaw, Coleman, Evcon 24V, 1/2" x 1/2" inlet/Straight outlet, Dual Standing Pilot, Step Opening, Mobile Home, Gas Valve Replacement w/Two 1/2" Side Outlets & Reducer Bushing (1/2" x 3/8") ...Missing: intertherm
Apr 07, 2018 | Intertherm Heating & Cooling
ZNEN 150 Scooter Type F11 Gas type?
Regular 86 or 87 octane gas will work fine.
Oct 10, 2017 | GAS Motorcycles
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
My brand new 38 gallon GE water heater does not ignite. I follow the instructions, hold down button in pilot position, heater dial in pilot mode and push the piezoelectric button several times. I look...
Check that gas is turned ON. Gas handle is parallel same direction as gas line.
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
Make sure that type of gas matches water heater. Natural gas and propane gas are two different types of gas. check label on side of tank for type of gas NG or LP.
Call GE 1-800-432-2737
Copy following links:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene
h
Aug 11, 2013 | General Electric Water Heaters
Gas valve faultdetected
Copy following link to troubleshoot by type of gas control valve, and read how to replace gas control:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
There are basically two types of Honeywell gas control valves.
One for atmospheric-vented water heater, and one for power-vented
For both types of controls: 8 flash + 3 flash error: replace gas control valve.
Water heater does not need to be drained to replace this gas control.
Apr 01, 2013 | Honeywell Water Heaters
What is a liquid gas stove?
A liquid gas stove is a type of stove that uses a fuel tank in order to operate. Liquid gas stoves are capable of burning different types of fuels like alcohol, white gas, automobile gas, and kerosene.
Oct 25, 2012 | Camping, Backpacking & Hiking
Gas hot water heater won't lite
Copy following link for troubleshoot by type of gas control valve, depending on type, model, brand and age of water heater.
Copy following link for testing and replacing thermocouple or thermopile, and general steps for cleaning air intake depending on year, brand, and type, and age of gas water heater.
http://waterheatertimer.org/How-to-replace-thermocouple.html
If you have tankless, then copy following link for possible help
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 21, 2012 | Water Heaters
Why is there moisture in my gas valve
10-20-12.
Product not identified, type of gas control unknown, type of gas not known.
Add a comment with specifics, for best answer.
Copy following links to identify tank-type water heater gas control valve thermostat.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Incoming gas line should have a 3" sediment and drip leg that creates low spot in gas line. Remove cap off end of drip leg and clean out.
Have plumber bleed gas line, and check pressure.
Oct 18, 2012 | Bosch Water Heaters
Rheem RTG53DVP code 82
Before calling service technician, open following link for resources including error codes, Rheem chat and possible manual:
Error codes are considered start-point for troubleshooting, and give service technician direction for isolating problem.
Error 82 appears as 'gas type data failure' > 'Program PC board for proper gas type.'
Gas type is choice between LP gas and NG natural gas.
Gas type programming is controlled with dip switch setting.
I do not have service manual for product, and would not suggest changing dip switches without specific information beforehand.
Aug 16, 2011 | Rheem RTG53DVP Direct Vent Liquid Propane...
Will a d15b7 water pump be compatiable with a d16y8 water pump
I hope this helps, it all I could find.
1991
CRXL4 - 1.5L 1493cc type D15B2 - MFI GAS SOHC
2 vehicles
1988 - 1989
CRX 1500 HFL4 - 1.5L 1493cc - MFI GAS SOHC
3 vehicles
1988 - 1990
CRX DXL4 - 1.5L 1493cc type D15B2 - MFI GAS SOHC
2 vehicles
1990 - 1991
CRX HFL4 - 1.5L 1493cc type D15B6 - MFI GAS SOHC
4 vehicles
1988 - 1991
CRX SIL4 - 1.6L 1590cc type D16A6 - MFI GAS SOHC
4 vehicles
1988 - 1991
CivicL4 - 1.5L 1493cc - MFI GAS SOHC
1 vehicles
1988
Civic 1500 DXL4 - 1.5L 1493cc - MFI GAS SOHC
4 vehicles
1988 - 1991
Civic 4WDL4 - 1.6L 1590cc type D16A6 - MFI GAS SOHC
3 vehicles
1989 - 1991
Civic CXL4 - 1.5L 1493cc - GAS
4 vehicles
1992 - 1995
Civic CXL4 - 1.5L 1493cc type D15B8 - MFI GAS SOHC
4 vehicles
1988 - 1991
Civic DXL4 - 1.5L 1493cc type D15B2 - MFI GAS SOHC
4 vehicles
1992 - 1995
Civic DXL4 - 1.5L 1493cc type D15B7 - MFI GAS SOHC
3 vehicles
1993 - 1995
Civic Del Sol SL4 - 1.5L 1493cc type D15B7 - MFI GAS SOHC
2 vehicles
1990 - 1991
Civic EXL4 - 1.6L 1590cc type D16A6 - MFI GAS SOHC
4 vehicles
1988 - 1991
Civic LXL4 - 1.5L 1493cc type D15B2 - MFI GAS SOHC
4 vehicles
1992 - 1995
Civic LXL4 - 1.5L 1493cc type D15B7 - MFI GAS SOHC
1 vehicles
1988
Civic SEL4 - 1.5L 1493cc - GAS
3 vehicles
1989 - 1991
Civic SIL4 - 1.6L 1590cc type D16A6 - MFI GAS SOHC
2 vehicles
1992 - 1993
Civic VXL4 - 1.5L 1493cc type D15Z1 - MFI GAS SOHC
Jul 11, 2011 | Honda Civic Cars & Trucks
Mi T M WP-2700-4MHB Pressure Washer Logo
281 people viewed this question
Top Mi T M Garden Experts
JOHN LAPIER
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
