Maxwell 1042 primeste programul dar nu incepe sa spele, nu ia apa(electrovalva nu este alimentata cu tensiune),porneste intai pompa evacuare dupa care se opreste si nu mai face nimic,iar led-ul de spalare ramane aprins la fel si cel de zavorare.Executa numai programul de stoarcere.
smartr10U
  • 1305 Answers
SOURCE: quisiera saber si hay que cambiar tarjeta
Checkas aqui... http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WTW6600&siteCd=WHRCOM porque hay informacion en espanol en los instruciones por tu lavadora.. los instruciones dice: Oprima Pausa/Anulación (PAUSE CANCEL) una vez para despejar el código. Presione Inicio (START). Si el código aparece nuevamente, llame al servicio técnico.
Posted on Jun 05, 2009
SOURCE: de ce nu citeste de la subtitrare tot cuvintul?
CAN BE SOLVED IF YOU CHANGE THE CHARACTER CODE FOR SUBTITLE, LG= PRESS 5 SECOND ON SUBTITLE BUTTON AND SELECT ANOTHER LANG ID
Posted on Aug 07, 2009
SOURCE: Tengo una lavadora Whirlpool modelo LXR7144EQ1 que
tengo una lavadora whirlpool, el problema es que no gira para exprimir, todo lo demás funciona, el motor recibe la señal para la función exprimir, sin embargo la transmisión no funciona.
Posted on Dec 08, 2010
  • 6277 Answers
SOURCE: la cuve se promene il est po fix comme il manque
Pardon- en Anglaise!
Hi from retired Englishman in SW France
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 18, 2011
SOURCE: mi lavadora whirlpool cabrio al
mi lavadora se bloqueo y solo dice ld
Posted on May 17, 2011
Salut nu merge abs la opel vectra a 94 poate cineva sa ma ajute
Pai ce arata:ABS aprins pe bord:sensori defecti sau deplasati,mizerie prinsa sub senzor.Daca dai roata(rotile) jos,gasesti senzorul si il tragi afara cu grija sa nu il rupi,verifici daca roata cu caneluri de sub el este curata,il cureti de pilitura si alte resturi,verifici cablul de legatura,il pui la loc impins pana atinge(misti roata sa auzi,dupa asta il tragi 1/2 mm inapoi,sa nu atinga.In cel mai rau caz este placa de control de pe pompa acolo deja nu te descurci singur.La calculator iti poate aparea care senzor se da defect/deplasat dar este relativ.De obicei,daca nimeresti se stinge si beculetul.
Oct 22, 2013 | 2000 Chrysler Grand Voyager
Nu porneste windowsul dupa instalare care este cauza
E destul de generica descrierea ta...fi mai exact..ce configuratie are calculatorul tau pt inceput?cauzele pot fi multiple
Nov 28, 2012 | Computers & Internet
Buna ziua am si eu un tel nokia X3-02 si nu merge, cind bag o cartela in el imi spune (enter restriction code) ma-m tot uitat pe net si nu ii gasesc un cod de deblocare, tel la-m primit. este adus din...
Bun? ?nseamn? c? telefonul mobil este blocat la re?ea, ave?i posibilitatea s? debloca?i telefonul mobil prin coduri debloca .. mod sigur cea mai buna si de deblocare este de coduri debloca ?i cererea mea personal? este c? nu merg pentru programul de deblocare, deoarece, uneori, software-ul s-ar putea ob?ine corupt ?i poate datele dumneavoastr? vor fi pierdute din cauza c? ?i, de asemenea, dont du-te pentru deblocarea gratuit, deoarece codul generat de circula?ie pot merge gre?it uneori, sa-mi experien?? nepl?cut?, a?a c? am mers pentru deblocarea de codurile din superunlockcodes ?i unlocked.you pot ?ncerca prea dar se vedea ?n acest dac? ?ara dumneavoastr? ?i furnizorul este listat .. deoarece pentru unele servicii sunt disponibile numai coduri .. verifica cu faptul c? ?i ?n cazul ?n care furnizorul de ?ara dumneavoastr? este listat, apoi ob?ine coduri ?i de a debloca telefonul mobil ..
Sep 21, 2011 | NokiaFree Unlock Codes Calculator
PROBLEMA ESTE CA PORNESC MONITORUL ,DOUA SECUNDE MERGE SI PE URMA ECRAN NEGRU DAR MONITORUL FUNCTIONEAZA SI SE VEDE PE ECRAN DAR FARA LUMINA .CE SOLUTIE IMI RECOMANDATI CONDENSATOARELE LE AM SCHIMBAT SI...
Uite, problema este in invertor, multiplicatorul de tensiune pentru alimentarea lampilor. Spune te rog ce condensatoare ai schimbat, in ce modul. De obicei (95%) aceasta problema e cauzata de transformatorul din invertor, cu timpul se deterioreaza sau se arde vreo bobina din interiorul sau si trebuie de sostituit cu altul nou. Si, vezi daca in invertor sunt rezistente variabile, incearca sa le reglezi putin.
Jun 06, 2011 | Acer AL511 15" Flat Panel LCD Monitor
Am instalat LG GH22NS40 in bios il vede dar nu
Verifica alimentarea, schimba priza SATA, asigurate ca e in prima sau a doua (celelalte doua sint cu probleme de driver) . Daca totul e in regula ti-a aparut in My Computer.
Pune un disc in el si incearca sa il deschizi in Explorer - daca nu e acolo (unitatea apare ca goala) sau dicul apare ca e gol atunci LG-ul e defect. Ca sa fi sigur de asta incearcal in alt pc.
Mar 17, 2010 | Soyo KT600 Dragon Plus Motherboard
NU SE MAI INCARCA SI NU STIU CE SA MAI FAK...NICI MACAR NU SE PORNESTE!
una,trebuie sa lasi mai mult in priza daca l-ai descarcat complet,trebuie sa verifici daca este conectat correct si lasa-l sa se incarce in manual scrie ca are o autonomie de 19 ore ar trebui ca macar dupa 17 ore sa il pui la incarcat oricum daca e nou trebuie sa incarci 16 ore de 3 ori pentru a formata acumulatoul.
Dec 01, 2009 | Nintendo DS Lite Console
Nu se mai incarca!!
buna,trebuie sa lasi mai mult in priza daca l-ai descarcat complet,trebuie sa verifici daca este conectat correct si lasa-l sa se incarce in manual scrie ca are o autonomie de 19 ore ar trebui ca macar dupa 17 ore sa il pui la incarcat oricum daca e nou trebuie sa incarci 16 ore de 3 ori pentru a formata acumulatoul.
Nokia 2630
Am si eu un nokia 2630.*** am scapat eu de "Pliculetul" care i-mi inchidea tel MENIU - MESAJE - STERGERE MESAJE - TOATE MESAJELE. DECI nu am reusit sa sterg dar apasand continu tasta OK am reusit sa apas in momentul in care a aparut pliculetul si a inceput sa stearga dar nu in totalitate ca sa inchis tel, am repetat procedeul si iar...,si iar... dar observam cu cat se sterg mai multe msg cu atat mai repede apare pliculetul , trebuia sa ma misc mai repede cu tastele telefonului pana am ajuns la ultimul si nu mai reuseam , am trimis cateva msg de pe un alt tel si sa marit putin timpul de aparitie al pliculetului ,am mai incercat o data si GATA Va doresc succes si multa rabdare. (driver777mary)
Aug 29, 2009 | Audiovox CDM8910BM
Realtek hd audio manager
Ia driverele pentru modelul tau de aici: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5LD2-VM , selecteaza mai intai ce sistem de operare folosesti si descarcale si instaleazale exact in ordinea de acolo(mai putin cele de bios) Bafta.
May 03, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Washing Machines Logo
205 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
