Question about Kwikset 4 Lido Lh Passage Levers Satin Chrome 200ll 26d
Trying to replace a door handle, but the latch mechanism on the old handle is stuck in the door/doorframe.....can't open the door and can't remove the latch cylinder.....advise please and thank you
    Problem Solver:
  • 5 Answers
Can you pull the hinge pins so you can remove the door. if so that will make it easier to work on
Posted on Oct 15, 2010
How do you remove the rear door panels on 1997 pathfinder
remove the trim around your interior door handle then pull on the metal rod that is connected to the handle, and the door should open
Feb 20, 2014 | Nissan Pathfinder Cars & Trucks
Both door locks do not work properly. I can only open the drivers side door from the inside. And the passengers side door will not open at all. This is on a 1999 Ford Explorer Sport.
Do any of the door handles inside or out feel sloppy (when you pull on them does it feel like there is nothing connected to them)?
If so that the levers on the latches are probably rusted up and sticking. Say for example the outside door handle lever that is attached to the door latch is stuck half way in the open position it will not allow the door lock mechanism to lock or unlock. The door will still latch and stay closed because the lever will not be stuck far enough to release the latch mechanism from hold on to the striker.
I have had pretty good luck removing the door latch (the part that actually holds the door closed) and soaking in penetrating lube and working all the levers until they move freely.
As far as the door that doesn't open I suspect it is stuck in the lock position and one of the handle mechanisms is in the partial up position. Again the symptom would be a sloppy door handle. That lever will need to be put back in its normal resting position before the door can be unlocked. This can be done with a slim jim. Once you have the door panel apart on the door that still opens you will be able to see the parts you need to move. You can then use that knowledge to move those parts on the other door that doesn't open.
If you don't have any experience with a lockout kit (i suspect most people do not) that that's the best way I can describe how you can do this yourself.
Sep 29, 2010 | 1999 Ford Explorer
My bedroom door latch is stuck. The mechanism that would have connected to the square rod has broken in to fragments. I am on the side where the door frame obscures clear access to the edge of the door so...
Do you have access to the hinge pins? If yes, remove them - remove the door - replace the handset.
If not, remove the handle by hack saw if necessary ... open it manually ... use a screw driver ... replace the handset.
Jun 03, 2010 | Garden
1993 Cutlass Supreme S 4 door sedan Drivers side front door locked when door was open, the locking mechanism is stuck is stuck and the door can not be closed. How can this be fixedd?
take a screwdriver and put in gap of mechanism and apply pressure while lifting door handle the latch should open if it falls back means spring is broken on latch will need to remove door panel and the 3 screws that hold it in place can get a replacement at a salvage yard for a few bucks
Dec 14, 2009 | 1993 Oldsmobile Cutlass Supreme
1972 corvette stingray, driver side door does not open fron either inside or outside.
Sounds like the door latch mechanism is worn out.
The door latch mechanism for your door is operated by rods, from the inside door handle, and the outside door handle.
It is highly unlikely, (Though not impossible), that all those two rods have fallen off. (Spring clips hold the rods in place. Opening Rod Control Clip. In the link below they are shown as Item E)
With the window all the way down, carefully use a long flat tip screwdriver, to push down on the lever for the door latch mechanism, to open the door. Make sure the lever for the door lock, in the door latch mechanism, is in the fully unlock position.
This link may help show you the inner door hardware, I'm referring to above,
http://www.mamotorworks.com/corvette-c3-door-hardware+1968+1982-inner-1-106-9491.html
You can see that when you pull out on the inner door handle, it pulls a rod forward. This rod is attached to a Bellcrank. The Bellcrank in turn pulls down on another rod, which pulls down on a small lever in the door latch mechanism, to release the door latch.
When you push down on the outside door handle, it pushes a small rod that is attached to that same lever as the inner door handle. Looking down through the window opening in the door, it is that lever that you're trying to push down, to open the door.
Viewing down through the window opening, try to operate the outside door latch a little. Watch to see what lever it tries to move. That's the lever you have to move Down, with the flat tip screwdriver.
With the door open, it is a matter to check out,
1.The Inside Door Opening Control, (The inside door handle is attached to it), to see if the locking part of it is functioning correctly. Make sure that it goes to the full Unlocked position.
2.The Door Latch Mechanism. Make sure it is functioning correctly. It, along with the various door hardware parts inside the door, needs to be lubricated at specific intervals. The more it's used, the higher the interval rate goes up. (I find that owners seem to Skip this task a lot! I use Lubriplate White Lithium spray)
To replace the door latch mechanism, I suggest you buy a manual for your car, so you can view all of the door hardware to remove, to remove the door panel. Then view how the spring clips come off of the rods, and the three screws come out of the door latch mechanism.
Jul 12, 2009 | 1972 Chevrolet Corvette
Rear door stuck on 1997 Pathfinder...Have
go inside, lift on handle, then beat the **** out of the door pounding it like your trapped in it trying to get out. latch mechanism is probably corroded and froze shut. once open, spray with wd40 and work the lever a lot. then get door panel off to see if handle is broken inside
Jun 16, 2009 | Nissan Pathfinder Cars & Trucks
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Driver's side door power locks are stuck; door stuck shut.
sounds like the rods are disconnected the clips hold the rods in place the latching mechanism holds the handle in place as well did you replace the speakers or did a shop? if a shop did then they caused this if you did then you may have caused this either way untill you reattach the rods none of it will work. you will have to manually open the door at the latch from inside teh door behind the panel.
Jul 16, 2008 | 1993 Ford Mustang
Door lock
When the actuator moves the latch up, it connects the outside door handle to the opening mechanism. When the latch is down, the outside door handle is disconnected from the mechanism so that it cannot be opened. So in this case your latch needs to be replaced, the latch or one of its parts is malfunctioning. the outside handle is never beening disconnected from the latch. remove the door panel visually inspect for damage, and take the proper repair
Jul 12, 2008 | 1997 Oldsmobile Cutlass Supreme
Dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Dec 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kwikset 4  Lido Lh Passage Levers Satin Chrome 200ll 26d Logo
224 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
