Question about Daewoo DV-T47N VCR
How to tune in daewoo vcr st862p for recording from the Tv
4 Suggested Answers
debbily
  • 101 Answers
SOURCE: recording on blaupunkt VCR RTV 430/540 from T.V
the VCR should record even without a tv attached.  The VCR will display what channel it is on.  The TV is only for viewing.
Cable hook up is ..
1. from the wall (or antenna) to the VCR input jack
2. from VCR output jack to TV input jack
Most TVs use channel 3 for VCR viewing.  You will need to hit the TV/VCR button on the VCR also.
Posted on Oct 13, 2007
SOURCE: daewoo tv/vcr combo ccodes
Hi here are some codes I have 0278 0624 If they dont work try programing the VCR
first then the TV. To program the VCR put a tape in and put it on play after you put
the code in hit the power button the vcr should stop playing. If that works then program the TV.
Some TV/VCR combo's require two codes. Good Luck
Posted on Feb 19, 2009
SOURCE: I NEED A MANUAL FOR A DAEWOO DF4150p dvd recorder/ vcr combo please help
go to Daewoo website and download it
Posted on Aug 07, 2009
I want to set up my video recorder to my tv and have forgotten how to do it. I have connected the two by aeriel but cannot see what else to do.
Youe aerial should be in the rear of the VCR & the other cable (flylead) should come from the output connection of the VCR & into the TV. To easily find the VCR channel insert a film tape into the video & press play, now selecting the VCR channel on the TV (EG. channel number 0) now you will need to go into the manual tuning on the TV & search until it finds the playback film, once this happens, store this setting. An easier alternative would be to buy a scart connector & connect this from the VCR to the TV & then the video channel will show on the AV setting on the TV, this saves you any tuning problem.
Oct 14, 2009 | Daewoo Televison & Video
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Vcr record a show
If you tuned desired chanel in VCR Tuning system, you can record it while TV remains Off.
Aug 01, 2008 | Televison & Video
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Vcr won't record tv
You have to plug the antenna to the VCR, in the "Antenna IN" plug, from there it goes to the "TV OUT".
You use the VCR to tune the TV and choose record according to your VCR model.
Hope That Helps!
Jan 26, 2008 | Televison & Video
Daewoo DV-T47N VCR Logo
88 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
