Question about DCS RDS-486GD Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
DCS RD-486GD Gas Range with 2 electric ovens. The main (larger) oven no longer heats reliably. Sometimes it works fine coming up to temp in 10-15 minutes. Other times, there is some heat but it never gets up to the set temperature. The heating light stays on for a very long time (30 minutes or more) without any additional heating. Sometimes, switching to convection will heat it to temp. There is no clear pattern as to when it will work or not. Any suggestions?
  • jonveach Oct 15, 2010
    Thank you for your quick reponse! This sounds reasonable. Is this something for an experienced DIYer to handle? (We would like to have this fixed withing the next few days.)
    Yeah, after looking at it further, I think I'll let an professional handle this. Thank you for your help!
  • 6,993 Answers
the problem should be from the heating element of your electric oven. The heating element is weak, that why its not heating reliably.
Also, there might be some partial contact, that is, the wire connected to the heating element might have loose contact partially, due to past heat coming out from the oven.
You need to open/disassemble the oven, check the wires connected to the heating element and see if they are intact. If its intact, then you might have to replace the heating element, for the electric oven to work efficiently again.
I hope this helps.
Good luck.
Posted on Oct 15, 2010
  • Walesarumi
    Walesarumi Oct 15, 2010
    Hi, this depends on your technical know-how/ability. Its a matter of disassembling the electric oven. But it would be better you don't start what you cannot finish.
    You can give it to an experienced repairman to fix it for you since you would be needing it in the next few days. A professional touch will make repairs faster.
    Good luck.
10 year old DCS Oven does ignite. Oven ignitor glows but maybe not enough to trigger LP from being introduced?
just because the ignitor glows it doesn't mean it's good,it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,usually if the flame doesn't ignite in around 40 seconds the ignitor is bad.also check the burner tube,your model number doesn't come up so i don't know if you have one or two ignitors in this oven but i've found that when the ignitor starts to fail and the customer waits to long to have it looked at the ignitor burns a hole in the tube and then both the ignitor and tube has to be changed,hope this helps and good luck with your oven.
Jul 19, 2013 | DCS RGU-486GD-L Range 48", 6 Burner,...
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
DCS RD 486-GD Oven thermostat small capillary torn. where can i buy for replacement of thermostat.
Hello everyone,
I am looking for Capillary temperature control Thermostat. nybody knows where can I find this part in Toronto?(GTA)
Thanks
Manoo
Nov 23, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
All 6 ranges and the large oven work well.the small oven won't li
My gas oven stopped working properly - called in the repair man and he replaced two of the three ceramic ignitors. (I have a two oven model). Apparently they only last / work well for 3-5 years. Kinda sounded crazy to me - but verified on the internet they are required to be replaced. Not sure I'd call the repair man next time - get the part yourself, one screw & two wires to replace. I'm no expert - but that solved my problem.
May 22, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
Large oven is not heating properly.
Had same issue - replaced the ceramic ignitors and most of my problem was solved. Apparently ignitors require replacement every 3-5 years. When they start to go it takes forever for your oven to heat up ... they don't glow properly causes the gas valve stays partially closed - ie hence less flame/heat. It may also significantly increase the amount of time it takes for the burner to light at all - essentially for the same reason.
On my oven the other issue was the burner itself ... it had corroded somewhat so the flame didn't automatically 'move' around to the other side of the burner. I removed the burner & cleaned the surface with a brass brush - problem soved. So essentially I had two issues - burner requiring maintenance & replacment of the ignitors.
As an aside I'm no expert - just relaying my experience.
May 11, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
May 21, 2009 | Kitchen Ranges
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Help in Replacing broiler igniter DCS RG-486GD
Jeff,
You have to remove the back of the range; the wires plug into the gas valve that controls gas to the broiler.  They detach by pulling on the slip on connector.
Aug 05, 2008 | DCS RGS-486GD Gas Kitchen Range
DCS gas oven locked
take a wire clothes hanger and go at the top of the door from the side hook the lock lever and pull this will unlock the door I' done this a thousand times and fun this can work on your last nerve sometimes but then again sometimes they go great good luck
Dec 26, 2007 | DCS RGS-486GD Gas Kitchen Range
DCS RDS-486GD Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
380 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
paulcarew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
