Question about Kenmore 80754 Top Load Stacked Washer / Dryer
Kenmore top load washer machine
The washer fills with water then stops if i drain the water out then it will turn back on or should i say start to fill again but nothing else happens what to do
    Sergeant:
    Champion:
  • 359 Answers
Check that none of your hoses are blocked, by pulling the back cover off. If any of these hoses r blocked it will stop the washing machine from working same thing happened to me and thats how i fixed it
Posted on Jun 02, 2008
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
    if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
    Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
    Kenmore topload washing machine that wont switch to drain
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
    Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
    See the Service Manual for how to test / replace the timer.
    Apr 16, 2010 | Kenmore Washing Machines
    Washer continues to fill and does not stop. is there a level or pressure switch that is problem or something else? Kenmore 80 series
    if there is no water leaking from the unit.then stop the washer pull your drain hose up so it is at least as high as the top of the washer make sure not to to take it all the way out of the wall.you should here water draining out of the hose once the water has stopped restart you washer and it should stop filling.if it does not the yes you have a fill valve sensor problem.the drain hose usually always holds some water and during the filling process if the drain hose if very low it will cause the water to start gravity eeding out of the washer that is why raising the hose helps out.i hope this helps your problem.i would like to now how it worked out for you good luck.
    Jan 22, 2010 | Kenmore 15864/15862 Top Load Washer
    Washer wont agitate or stop filling on any setting
    Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
    Nov 18, 2009 | Kenmore 24712 Top Load Washer
    Leaks out when it is filling.
    Make sure the drain hose is higher than the top of the washer tub.
    Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
    Water will not stop filling for the wash or rinse cycles
    OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
    May 30, 2009 | Kenmore Washing Machines
    Kenmore 80 series washer doesn't stop filling up with water
    Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
    http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
    Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
    Feb 11, 2009 | Kenmore 22422 Top Load Washer
    Kenmore heavy duty 70 series washer
    The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
    Apr 23, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80754 Top Load Stacked Washer / Dryer Logo
    67 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
