Question about Honeywell Programmable Thermostat Heater
I JUST INSTALLED HONEYWELL TH6110D1021 THERMOSTAT FOR A STEAM ZONE VALVE. I SET THE THERMOSTAT FUNCTION BY PRESSING THE UP ARROW AND FAN BUTTON. THEN CHANGING THE RIGHT NUMBER TO 2. NOW I WANT TO CHANGE THE TEMPERATURE DIFFERENTIAL SO THE THERMOSTAT WILL NOT CALL AGAIN UNTIL THE TEMPERATURE DROPS AT LEAST A FEW DEGREES. IF NOT COULD HELP ME FIND WERE TO FIND THE DIFFERENT CODES ON LINE BECAUSE I DO NOT HAVE THE INSTALATION GUIDE.
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Suprizingly enough there is an abundance of manuals for your Honeywell Programmable Thermostat. Use this link and at the bottom of the page you can download any of the manuals.
http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1021
Just note that pop ups must be enabled to download the manuals
Printable Quick Reference Sheet (after download)
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1778ES.pdf
Thanks for choosing FixYa,
Kellly
Posted on Oct 15, 2010
Honeywell focus pro 6000 thermostat
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
Jul 25, 2014 | Honeywell Focus Pro 6000 Programmable...
I have installed RTH8580WF thermostat for heat pump in my condo. I have R O Y G and I added wire. It seems it works opposite with 170=2 cools when heat on and teas when cool on.
Press the FAN & the up arrow @ the same time to get into installation programming. Follow the set up numbers correlating to options in the install instructions...Make sure it is programmed for heat pump & if you have Auxillary heat. Hit Next until you get to the reversing valve position O or B ( reversing valve energized in a call for heat or cool) and switch it to the opposite of what is in the current program. Hit Done & you should be good.
Oct 23, 2013 | Honeywell RTH8580WF WiFi Thermostat
Honeywell th6000 thermostat installed. It shows only heat-or off- no cool. The fan doesn't show up as auto or on. Now air conditioner has turned on and it is -15
If you just installed the stat, you need to enter installers programing to set it up. To do thi, press and hold "UP" and "FAN" until a number on the left and right show up. The left number is the function and the right number is the setting. You do not specify what type of system you have, so i cannot tell you exactly what settings. But here is a link to the installers manual. the installers program settings is about half way down. http://www.forwardthinking.honeywell.com/related_links/thermostats/focuspro_6000/install/69_1920es.pdf
Feb 06, 2010 | Honeywell Programmable Thermostat Heater
Valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat TH6110D1021. Blower comes on
Hi, You are right, fan is on a time delay in the heating cycle, and after burners fire that is when this delay comes into play. You have a preset factory temperature that determines the cycle on time for the fan, and the off time after the burners shut down also. This will not be in the thermostat, but in the fan/limit control the is mounted on the face of the furnace, with a probe inserted into the fire box.Depending on how old or new this unit is, will depend on the type control you have.It may be just a high limit switch, or the 1st I mentioned.If so, It rotates in the burner as the temperature rises, to turn the fan on and off.Disconnect power, remove cover, and 2 screws.Slowly remove the control and gently clean the probe. Turn the dial if this one has it and you will be able to hear it click. This click is contacts closing to start fan operation.Reinsert and try again. If problem continues, you will have to replace it.They do tend to stick closed/on, in the heat cycle from time to time and a cleaning sometimes will solve this problem. Not knowing how old this furnace is and type, make it difficult to give you a correct diagnosis, so check this fan control as I have explained, and if your system is of a different type, please let me no so I can correct this problem. Sincerely,
Shastalaker7
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
I want to change my TH6110D1013 honeywell thermostat to celsius . how do i do it?
You need to go into the setup mode to change it. Push and hold the i button along with the increase and decrease buttons. All the segments on the display will appear for about three seconds, then setup number will appear to the left and factory setting to the right. Change the setup number by pressing the (i) button until you get to 14. This is the degree temp. display, factory setting is 00. Use the arrow up key to change to 01 (celsius).To exit setup, push and hold the(i) key until the display returns to normal.
Oct 09, 2009 | Honeywell Programmable Thermostat Heater
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
984 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
