Question about Malber P21 Front Load Washer
Machine won't run through cycles automaticly
Perhaps I'm not familiar with the machine enough, but the cycle dial seems to get stuck in one position and I have to manualy turn the dial to move it along to the next cycle ( spin, ect.) I just had it in for repair and was told it was fixed, but this problem continues. it is a Malber WD 800, the older version of the P21 I think. thanks for any help. any one have a users manual? thanks
  • Anonymous Sep 04, 2008
    malber p 15
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Sounds to me it might be a thermal pause, if your unit is running and then is required to heat up at a certain point and reach a certain tempurature before it advances, the heater is probably not coming on. The unit will therefore not advance.
Sgt 48
Posted on Jun 03, 2008
Door rubbers heating up to much
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Dec 25, 2014 | Samsung Refrigerators
Out side gets really hot why?
Jun 30, 2014 | Kenmore Refrigerators
SPEED QUEEN WASHER WON'T ALWAYS AGITATE
see this causes:
Lid switch
test for open or defective use the DVOM OR VOM
Motor coupler
COUPLER wears see the diagram
Belts
broken or worn replace
Clutch
clutch worn replace
Drive motor
bearing and winding burn in one directionor defective by overheating
Drive pulleys
drive pulley frozen or worn replace
Transmission
broken gear or worn
Agitator
can be worn too replace
Jun 21, 2012 | Washing Machines
Cycle dial doesn't advance automatically anymore. I saw some listed problems that sounded similar, but not exact. Washer will work in all cycles, but only when I watch and move the dial manually.
Hello & Welcome to FixYa
Its seems that the Timer is stuck, as everything else is working fine in the unit and the dial ust gets stuck and so won't complete the cycle so the problem is with the Timer motor going bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 24, 2010 | Kenmore 15522 Built-in Dishwasher
I have a 15 yr old Whirlpool washer that has run great. During a cycle, it stopped full of water. I moved the dial around to different areas pushing it in and out and got a cyle to run long enough to pump...
Not always a Timer issue. could be stopping at the cold fill part of the cycle which is the 8 o clock position on the dial. This would be fault with the cold fill vavle.
Sep 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My dishwasher is starting it's cycle, then running for a minute or 2, then it stops and drains itself, then starts the cycle over and repeats this. It won't continue it's cycle and it seems to be stuck in...
you seem to be stuck in a 'quick rinse' cycle. double check your buttons as well as your timer/dial to see if you are using the normal wash cycle. especially check the buttons. good luck
Nov 02, 2009 | Frigidaire Dishwashers
Machine will not automatically advance thru cycles
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
May 03, 2009 | Washing Machines
IT IS STUCK , IT JUST HUMMS ,CYCLE DOES NOT START
I PULLED THE DISHWASHER OUT FROM UNDER MY KITCHEN TOP. THEN TRIED IT AGAIN AND IT STARTED WORKING. WATER WAS ENTERING THE MACHINE AS IT SHOULD AND THE WHOLE CYCLE WAS COMPLETED FROM WASHING TO DRYING. BUT WITH THE ODD RATTLING SOUND NOT COOMING FROM DISHES. I ASSUME THE INLET PIPE WAS PROBABLY BENT THEREFORE BLOCKING WATER COMING IN BUT WHY NOW AFTER YEARS OF BEING IN THAT POSITION. THE OTHER THING I CHANGED WAS THE ELECTRIC SOCKET POINT- IE I PLUGGED IT IN SOMEWHERE ELSE BECAUSE MOVING IT MEANT THE LEAD COULD NOT REACH ORIGINAL SOCKET. HOPEFULLY WHEN I RETURN IT TO ORIGINAL POSITION EVERYTHING WILL BE WORKING. FUNNY THING HAPPENED THE WEEK BEFORE- MY WASHING MACHINE WAS STUCK IN MIDDLE OF A CYCLE . BUT STARTED WORKING THE FOLLOWING DAY. COULD IT BE MY ELECTRICITY PERHAPS - IE MY APPLIANCES ARE NOT RECEIVING ENOUGH CURRENT?
Dec 04, 2008 | Dishwashers
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Malber P21 Front Load Washer Logo
218 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
