Question about Microsoft Office Professional 2007 Full Version for PC
When i m loading the setup after some it's ask me path
    Master:
    Sergeant:
  • 381 Answers
Click next,
the path would be
c:\\program files\
if this does not solve it then
start the install again
Posted on Oct 15, 2010
A1 rotation from A0 roll
I could't understand the question exactly..I will try my level best, it may helps you..
T770 plotter having three media paths..
1. Sheet path
2. Roll 1
3. Roll 2..
After initializing, printer will ask to load the media, you have to specify the desired media selection ie sheet, Roll1, Roll2..
If U R selected roll one, message appears on screen "Open Roll 1 cover", you have to follow the message, once the paper is loaded in the path, printer has to detect the paper,it has to pull inside with the help of the roll feed motor..
In this case If UR selected Roll 1 on printer screen & inserted Roll 2 media, printer will runs Roll 1 motor, not roll 2 motor.. This problem U might be facing..
If my suggestion is not helping U, pl let me know exact problem what UR facing...
Apr 26, 2014 | HP DESIGNJET T770 Printer
What would cause insufficient flow to my egr valve? (i just replaced it)
ok , the valve is easy to test and clean but is only 10% of the path.
my bark test works.
i remove the EGR valve see 2 ports there. (twin holes)
one is vacuum side, (intake) the other is exh. side.
i plug the vacuum side, and start engine
this is what i call the bark test. if the exh port barks load ,it may be good. if dead, or weak, it is, fix that now. clean path.
if that works ok , i then check the vacuum path port of carbon blockage. i rod it out with a flex cable.ask
the electric side test are below.
see 253mb file here
http://hondatech.info/downloads/Auto/Manuals/Accord/
that is the FSM. burn it to cd, and run the setup'
Jan 31, 2014 | 1999 Honda Accord
Loading roll paper printhead path type 1
Switch on & observe the carriage behavior for hitting right ot left frames. Clean encoder with dry cloth to avoid ink marks on it & also check for damages.. if found replace it, check..
Enter in to service mode, scroll to carriage test, enter. Check for the result, if its failed, replace it..
Entering in service mode: Power off the printer by using through front panel power switch. Hold the color key switch on the printer using power switch mounted on front panel.Wait till "initializing" appears release the button, you can observe "service test" on panel scroll to carriage test> enter.
I hope you can solve the issue..
Dec 28, 2012 | HP DesignJet 1050c plus InkJet Printer
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
Printer is not printing with these pages alternating"online single load" and "load paper from single"
The printer is indicating that the paper path has been changed (either via the control pannel on the printer or by escape command) to the single sheet feeder.
I guess you are using Continuose Paper fed into the tractors at the front of the printer (Tractro 1), if this is the case you need to go into the menu on the printer and change the paper path back to Tractor 1.
Take the printer off-line by pressing the Online key
Press the Setup key
Press the key under "Paperway" in the display
Select Tractor 1
Press the key under "Set"
This should change the peer path to the front Tractor, if this does not work power the printer OFF and disconnect it from the computer system. Then power the printer back on again and again try changing the paper path as described above.
If you get the message LOAD SINGLE only when you send data to the pritner you need to check the paper path selected on the computer system.
Jan 25, 2010 | TallyGenicom 2280 Matrix Printer
I have a Tally T2245 with load error. ASF-R
Sounds like the paper path has been changed I guess you are using the front Tractor (tractor 1) to load continuose paper.
You need to go into the menu and change the paper path back to Tractor 1.
Disconnect the pritner from the computer system, and power the printer off and back on again to clear the buffer.
  • Take the printer off-line by pressing the Online key
  • Press the Setup key
  • Press the key under "Paperway" in the display
  • Select Tractor 1 (or Tractor 2 if fitted/required)
  • Press the key under "Set"
  • This should change the paper way back to Tractor 1
    Jun 23, 2009 | Tally T2245 Matrix Printer
    Windows vista will not load on my laptop
    Consider the following scenario. You use the net use command to map a network drive to the Sources folder. Then, you run the Setup program from the mapped drive to install Windows Vista. In this scenario, the installation may not finish successfully, and you may receive the following error message: Windows could not load device compatibility data.
    CAUSE loadTOCNode(1, 'cause'); This issue occurs if the Setup program cannot access files and folders that are located outside the Sources folder. The Setup program requires access to these files and folders to successfully complete the installation.
    RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue, use one of the following methods: • Do not map a drive directly to the Sources folder. Instead, use the net use command to map a drive to the parent folder that contains the Sources folder. • Run the Setup program by using a universal naming convention (UNC) path instead of by using the net use command to map a drive.
    Aug 21, 2008 | Computers & Internet
    Microsoft Office Professional 2007 Full Version for PC Logo
    14 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
