Question about Vacuums
Nutone Vacumn 450 built in vacumn system
Suction very bad - replaced with new bag - I'm thinking something stuck in hose
    Sergeant:
    Champion:
  • 359 Answers
Definately something stuck in the hose. Take the hose of and check for blockage.
Posted on Jun 02, 2008
My vacumn won't pick or suction up and bag is not full. I cleaned out the hose checked and belt running I have no other answer please help. It's an upright lux guardian
The output filter on that unit is HEPA and traps all particles. You need to clean or replace that filter because the airflow cannot leave through it and it wont develop suction.
Feb 06, 2015 | Vacuums
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
A Nutone CV-450 System with inlet nozzle switch issues
You are suffering a connection problem of the hose end fitting to the wall outlet. Either the hose is not aligned with the two pins in the wall outlet, or the pins in the outlet are dirty and not making good connection to the hose end fittting.
Jan 01, 2010 | Broan-NuTone CV450 Central Bagged Central...
Have a nutone CV-450. Suction is gone at the
The first thing to do is to disconnect the pipe coming into the unit. If there is suction there than you probably have a break in the line. If there is no suction when you disconnect the pipe coming into the unit than it is most likely the motor gasket. This gasket can sometimes get sucked into the motor causing problems. Remove the lid to the central vacuum, than disconnect the motor, you should be able to tell if maybe the gasket has been off center or if it has been sucked up in the motor.
Dec 13, 2009 | Broan-NuTone CV450 Central Bagged Central...
I need a relay board for a Nutone CV 450 12.6 amp dual motor vacumn unit. Where can I locate one? Part #??? Unit will run by itself, then shut off. Unit wll not run at all. It has a mind of its own....
Unfortunately I don't have a part number for you, but you can call this number 1800.322.2965. Tell them you need a new relay board for your system and they'll be able to help you. They cost around 99$. for anything else you might need, go to www.thinkvacuums.com
Sep 01, 2009 | Broan-NuTone CV450 Central Bagged Central...
There is no suction
Either the fan is not turning to generate the suction or there is a clog
Aug 29, 2009 | Broan-NuTone CV353 Central Vacuum
Volta ultima 2000 watt vacumn - hardly any suction at all
change your bag.or your motor is going bad so have that looked at.
Jul 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum is whistling and there is no suction through the hose.
Sometimes mine "wand" has no suction too. . . Make sure the vacumn column is clicked into the "standing" position, don't have it at an angle. Also you may have to play with the settings on the bottom part AND the power button together. I think this vacumn sucks (pardon the pun) mine turns off after 10 minutes of use, then I let it sit for an hour and then it'll start again. POS!
Apr 22, 2009 | Fantom Vacums XT450K Upright Vacuum
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
We have a beam built in vacumn system ( old one) there is virtually no suction coming through the hose. I suspect some sunflower seeds were picked up and clogging it somewhere. What to do?
You need to figure out if it is the hose that is clogged, or in the piping. If in the hose, you can use a long plumbers snake to try to remove the clog. If you have no suction in none of the outlets, then I would suspect the hose, or the main pipe came loose from the cannister. Also are you sure that the cannasiter is coming on? If the blockage is in the piping, you can use the plumbers snake there also.
Apr 30, 2008 | Vacuums
Vacuums Logo
76 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
