Question about Kenmore 51lb. Clear Ice Maker
I cleaned my ice machine yesterday and it is on but not making any ice.
    Sergeant:
    Champion:
  • 226 Answers
See if you cut it off the bar on the ice maker
Posted on Oct 15, 2010
Why isn't my U-Line 3018CLR making ice?
Isn't it obvious the compressor isn't running to freeze the water? Make sure the thermostat is working.
Jul 17, 2014 | ULINE U Line 3000 Series 3018CLRS41 20"...
How to clean a scotsman icemaker
WHAT SHOULDN'T BE DONE.
Never keep anything in the ice storage bin that is not ice; objects like wine or beer bottles are not only unsanitary, but the labels may slip off and plug up the drain. Never allow the machine to operate without regular. The machine will last longer if it is kept clean. Regular cleaning should happen at least once per year,and preferable twice. Some water conditions will dictate even more frequent cleaning of the ice making section, and some carpets or pets will dictate more frequent cleaning or the condenser.
WHAT SHOULD BE KEPT CLEAN?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
HOW TO CLEAN THE CABINET.
Wipe off any spills on the surface of the door and handle as they occur. If anything spilled on the door of gasket dries onto the surface, wash with soap and warm water to remove.
HOW TO CLEAN THE ICE STORAGE BIN.
The ice storage bin should be sanitized occasionally. It is usually convenient to sanitize the bin after the ice making system has been cleaned, and the storage bin empty. A sanitizing solution can be made of 1 ounce of household bleach and two gallons of hot (95 deg F.-115 deg F.)Water. Use a clean cloth and wipe down the interior of the ice storage bin with the sanitizing solution, pour some of the solution down the drain. Allow to dry.
HOW TO CLEAN THE CONDENSER.
The condenser is like a radiator on a car, it has fins and tubed that can become clogged. To clean:
1. Remove the kick plate.
2. Locate the condenser surface.
3. Vacuum the surface, remove all dust and lint.
4. Replace the kick plate.
CLEANING THE SYSTEM.
HOW TO CLEAN THE ICE MAKING SYSTEM.
1. Open the door and turn the ice machine control knob off.
2. Scoop out all of the ice, either discard it or save it in a ice chest or cooler.
3. Pour 4 ounces of Scotsman ice Machine Cleaner ( available from a local Scotsman Distributor or Dealer, ask for part number 19-0343-06- an 8 ounce bottle) into the ice machine reservoir.
4. Turn the ice machine control to ON.
5. Allow the machine to operate for about 2 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off of the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin interior.
10. Replace the ice removed in step 2.
The ice scoop should be washed regularly, wash it just like any other food container.
WARNING; Scotsman ice machine cleaner contains acids. These compounds may cause burns. If swallowed,DO NOT induce vomiting. Give large amounts of water or milk. Call Physician immediately. In case of skin contact,flush with water. Keep out of the reach of children. Always follow manufactures directions.
May 16, 2014 | Scotsman DCE33PA1BC 15in Built-in...
I have a Scotsman SCN60 nugget icemaker and when I add cleaning solution to reservoir it just stays there
Hi, Are you using Scotsman ice machine cleaner? and are you using the right amount?
1. Open the door and turn the ice machine control knob to off.
2. Scoop out all the ice, discard it.
3. Pour 4 ounces of Scotsman ice machine cleaner into the ice machine reservoir.
4. Turn the ice machine control to on.
5. Allow the machine to operate for about 2 to 3 hours.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off the liner.
9. Sanitize the bin liner.
Now a dirty evaporator plate will not stop it from making ice it will cause it to hang up on the plate during harvest cycle if machine is not making ice good then there is something else wrong but when you clean the machine also make sure you clean the condenser coil and fan if this is dirty this will cause it to slow down on production of ice.
Dec 19, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
We have a Frigidaire Gallery side by side frig. We have had many problems, but yesterday it froze up with icicles hanging and big chunks of ice. My husband cleaned it out and thought it was OK. We woke...
First thing to check is where the ice maker actually fills up to make sure that its not full of ice and causing an over spray of water into the machine. You can actually take the tube out from the back of the machine. If there is no ice in the tube, next thing to do is make sure that the ice maker isn't over flowing and calling for to much water when its filling,. You can do this by either removing the ice maker and visually looking or by reaching in and feeling to see if the ice maker is completely full of water. If it is then either your ice maker is going back or the water valve is not closing when the ice maker is done calling for water.
Nov 07, 2010 | Frigidaire Refrigerators
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Kenmore 51lb. Clear Ice Maker Logo
180 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
