Question about Asko Washing Machines
I have an Asko 10505 and have a leak in (I believe) the mixing valve. I need to see a parts diagram to know what to order. can you provide one? thanks
  • Asko Master
  • 2,605 Answers
Hello, Welcome to FixYa. If you want to email me at macmarkus@live.ca I can send the info you are requesting this evening...possible by AM tomorrow at the latest. Keep me posted on your progress or what you find. Good luck. Regards, Macmarkus :)
Posted on Oct 15, 2010
  • Mark MacDonald
    Mark MacDonald Oct 19, 2010
    Hi again,
    Do you still want the part breakdown for your Asko 10505 washer ?
    I just wanted to follow up on this since I hadn't seen a reply and in the event you emailed me and I had not received it. Let me know either way if you could I'd appreciate it.
    Regards,
    Macmarkus :)
Gnutti Sebastiano thermostatic mixing valve #1559-6I. Where can I get a clear diagram of parts and disassembly instructions?
Alan:
I am having the same issue with their 5 way diverter valve #2228-0. I've disassembled and removed the mixing valve and it seems to be in order but after a minute or so it goes luke warm. I've cleaned the assembly with CLR and it helped some but I still can't find the problem. All other fixtures in the bathroom are in good working order. I'm headed to the plumbing supply house next week and will let you know if they have any ideas.
Gregg
Dec 20, 2015 | Plumbing
My Asko 10505 washing machine used 110 litres water for one load. Is this too much water?
certainly is
check that the drain hose is above the washing machine into a tub as it may be running out as the tub fills
there are no valves , just the height of the hose above the tub
Oct 20, 2015 | Asko Washing Machines
Asko 10505
cylicon can easily fill the gap. it works. you can get this from a hardware store in tube .
hope this helps
Apr 15, 2014 | Washing Machines
Asko dishwasher 1875. Saying F2 fault. Reset doesnt fix. Water slowly running in constantly even when switched off. Pump runs if left on but if turned off it floods. any ideas?
Just wrote you a massive explanation then closed my window by accident. Lets try again!
From what you say, with water running even when powered off, this is certainly a mechanical failure of the water inlet valve. There will only be a couple of possible causes for this:
1) The valve is being jammed open by an obstruction, possibly grit in the water supply (did you have plumbing work done recently or work on the water supply in the street? This would be a classic cause). If an obstruction is the case then repeatedly starting a fill cycle, draining and satrting the fill again MAY shift the blockage.
2) There is a failure of the valve its self. Essentially it's just a valve with rubber seals operated by a small electro magnet and sometimes the seals fail (often as a result of a poor water supply allowing grit into the rubbers).
If the information at (1) above doesn't help, you may have to replace the valve (Though in examining it when you come to take it out, you may be able to locate and remove an obstruction).
To help you out there is a parts manual for your machine available in PDF here:
http://www.greatplainsapplianceparts.com/order/Parts%20Manuals/Asko/ASKO-Dishwasher/D3112%20(DW20.1)%20SS.pdf
Looks like the diagram on page 2 shows that you need part 135, although it seems to me that the author of the manual has got part 135 (Part No. 8073774 Cord Set) mixed up with part 140 ( Part No. 8073825 Inl. Valve Single 120V Sens.).
I imagine that if you go to the ASKO website and use the contact us option:
http://www.askousa.com/customer-care/contact-us/
They should be able to clear that up for you
Hope this all helps
Jul 28, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
Unable to locate any info on a model 10505 se # 982410041588
Hi, I may be mistaken but I don't think so, that number ( 10505 ) is for an Asko washer built in 1998, not a dishwasher. Do you require assistance with your washer ? I will watch for your reply. Macmarkus :)
Mar 17, 2010 | Asko Dishwashers
Asko 10505 will not spin the belt is not broken, tub fills and drains
Your washer unit is needing a new timer and replacement is needed if the part is available.
This will require some electrical experience to replace the timer unit or go to your local Sears repair and they will come out and repair your unit for a fee.
Jan 29, 2010 | Asko Washing Machines
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Leaking inlet valve on Asko 10505
Unfortunately, the only way to be 100% sure this won't happen again is to replace the inlet water valve. Especially if the problem is intermittent. You could live with it if you turn off your water taps when the machine is not in use.
Feb 19, 2009 | Asko W6021 Front Load Washer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
Washing Machines Logo
144 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
