Question about Apple Wireless Keyboard
Apple Wireless Keyboard key fell off and I need instructions as to how to put it back on. I have the key and the two white connector pieces that hold it on. The round rubber button is still intact. Can you send me any instructions? Thanks a lot.
    Master:
    Sergeant:
  • 381 Answers
You need to verify that the batteries are inserted correctly
Posted on Oct 15, 2010
My lenovo e530 few keys stop working due to spill
Go to Amazon.com and search for an aftermarket keyboard for you make and mdl. It would be a cheep fix (most likely under $25.00) if it doesn't come with instructions google replace keyboard and add your make and model. Most keyboards are held in by 4 or 6 screws accessed on the bottom of your computer. After you remove the screws open the computer and lift the old one carefully until you see a ribbon (flat wide wire) of cable there will be either a connector on the end that will lift out or at the computer a plastic connector attached to the computer that has a piece that will click away and the ribbon will come out. Put the new one in and put the screws back. Reboot and cross your fingers. Or you can use a USB or wireless keyboard, but that's not to portable.
Worst case get into the virtual keyboard thru access ability settings and you can use the mouse to type the letters your keyboard will not type. Good luck, Kevin
Aug 03, 2014 | Lenovo ThinkPad Edge E530 325978U 15.6"...
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
Row of characters stopped working
Sometimes the ribbon connector becomes disconnected from the connector on the motherboard. You can fix it by removing the connector inserting a slim piece of plastic and reinserting the connector.
May 02, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How to replace a key on an apple wireless keyboard
Go to the manufacturer website and put in your make and model and follow the instructions
Mar 19, 2011 | Apple Wireless Keyboard
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
My CTRL and v keys fell off of the keyboard and I can't get them back on. I can get the white plastic things back on the keys but not the keys onto the laptop. I have a Compaq V6000.
princessvero,
I will try my best to help you here, but u need a proper instruction on my to work around with the key, here's a link to show to how to assemble the key back to your keyboard.
Key assemble
Don't forget to rank my solution... Thanks/
Jan 09, 2009 | HP Compaq Presario V6000T Notebook
0 and - keys fell out!!!!
hey
This could be a little difficult to explain.. coz the white ring acts as a spring and putting it back on is not hard but difficult to explain.
See first of all on an acer laptop a key has 3 components
the key
the white thing (which holds the key in place)
and a black soft thingy (which actually gets pressed wen u press a button and acts like a spring)
first of all the white ring can be removed and refixed easily .
Youll see 4 small hook like structures on the palce where key needs to be placed ... first place the white ring over there, the white ring has 2 things which come into one another. (try referring to the key where in the white ring is still in place).
now if the black spring like thingy is removed from its place, place it in the center of the ring and put the key on, try moving the key a little, if the key and white ring are put correctly, this will produce a click like sound showing the key is locked by the white ring .. if the white ring is dismantled into 2 parts it could be a little tricky to put them back on.. in that case i guess ull have to check a fixed ring and try and replicate the same for this key
for further assistance feel free to mail me on:
kushalagarwal22@gmail.com
Cheers
Kushal
Aug 27, 2008 | Acer NSK8458AN Keyboard
Gateway notebook key fell off keyboard
Unfortunately, there is no instruction out there for this. My advice is to take one of the other key off in order to see how it fits, then put the key back on the same as the other. I suggest a key right next to the one that is off. Be very gentle and try to remove only the key, leaving the retainer.
Jul 16, 2008 | Gateway MX8711 Notebook
Keys coming loose on keyboard
I'm afraid that with them trying to make it as thin as possible that you may start seeing this problem all around. Not only is it a wireless computer but they should also state, "Be gentle". Haha
Apr 16, 2008 | Apple MacBook Air
My ibm thinkpad key ""Q" came loose
Situation 1. The key cap and key retainer fell off the keyboard and you cannot figure out how to assemble them back. keyboard-key-repair-1.jpg Carefully remove the cap from any other working key so the key retainer stays connected to the keyboard.
keyboard-key-repair-2.jpg Take a closer look at the key retainer, it’s connected to the keyboard at four different points.keyboard-key-repair-3.jpg Assemble the disconnected retainer the same way as one on the keyboard and put it back in place.keyboard-key-repair-4.jpg Put the key cap on the retainer and snap the cap back in place.keyboard-key-repair-5.jpg
Jan 13, 2008 | HP Pavilion dv1000 Notebook
Apple Wireless Keyboard Logo
268 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
