Question about Directv (DWO2-10024)
I bought a new hd box and have put the settings exactly the same as on my other boxes(which work fine) but when i check the siganl strength through the new box, im getting great reading from the odd numbered transponders and 0's for the even transponders
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
Recheck your dish direction and elevation you are probaly off just a hair and
hd receivers have to be fine tuned. They also may not get as high a signal
level as standard receivers
Posted on Nov 18, 2011
I have a Strong SRT 5066 Set top Box. I can't pick up any HD channels. Is this box HD compatible or do I need to buy a HD Box?
Just add the same problem. You need a HD set top box, supplied by your cable co. Your picture quality will depend on the strength of the HD signal. If you have correct box and signal, you may need to double click your remote select button to activate HD channels/
Jun 29, 2011 | Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Pixelation of TV channels via Settop box
Pixelation is caused by poor signal strength. Check the signal strength in the setup section. Unfortunately some boxes and TVs don't handle poor signal as well as others. It might be worthwhile trying a signal amplifier
Jun 12, 2010 | Televison & Video
Not getting HD from the set. I have an HD cable box. I bought an HDMI adapter, but still no HD.
The cable box output needs to be set to HD, 1080I, 720P, 1080P. If you call the cable company they should be able to set the box up to ouput a higher resolution. A way to check your hd would be to play a blu ray disk through a ps3 if you have friends with one or have one yourself. If it plays hd just fine you know for sure it's the cable box.
May 07, 2010 | Sony KP-57WS500 57" Rear Projection...
No antenna siganl strength
Antenna may not be compatible with DTV signals or not aimed correctly.  Go the www.dtvanswers.com and click on the Antennas tab at the top for more info.
Jun 02, 2009 | RCA Universal Remote Control
When I plug in my hdmi set top box my monitor says no signal
If an HDMI cable won't work, try Component Cables.
I went through the same hassle as you.
Jan 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
DTV conversion concerns
I just purchased a Magnovox converter at Wal-Mart with the coupon I ordered from the government program. Our TV is about 2 years old too and not HD. It has worked great. The reception and color is truly the best we've had in years. We live in the country about 50 miles from all the local stations and were told we would need a new antenna, so far the only channel we have problems with is the PBS. Not sure if it is antenna related or their signal strength. We don't have the problem until the sun comes up good. It has been great to get the additional channels that some stations have added. Hope this helps.
May 09, 2008 | Televison & Video
Directv (DWO2-10024) Logo
41 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
