Question about Sony Playstation 3 (PS3) Console
Ps3 shutdown now it will not restart . It tries but shuts down again
  • 104 Answers
Its also has a yellow light I assume This is know as yellow light Of Death which just recently happen to me. I just got a new one but u can fix it yourselve or call sony and ship it to them to fix ps3 shutdown now it will not restart . It tries - c5749b3.jpg Good Luck and Happy Gaming-Koscoe
Posted on Oct 15, 2010
Ps3 won't work
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Good luck.
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
Tip
Ps3 internet connection error 80028ea6
i got this error 80028ea6 while trying to connect my ps3 to the internet through ps3 proxy server. what fixed it for me is, I had to reset my proxy server (shut it down). Before shutting it down there is a tab for replacing files. Make sure you remove all files from this tab and then shutdown. next restart proxy server and make sure there is nothing under replace files tab. To prevent this error from happening again when you go to replace files, replace them one file at a time. proxy server can not replace more than one .pkg at a time.
on Aug 01, 2015 | Sony Playstation 3 (PS3) Console
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
Apr 19, 2010 | ASUS Eee PC 1000HE Netbook
When i turn on my ps3, it tells me it wasn't shut down properly and must turn it off again or else it shut downs by itself.
You can also try the steps below. Its from PlayStation Forum:
well as cookies.
I wish you good luck.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
I have owned a PS3 for 4 years now. I have had no real problems with the system itself. Today, 3/18/10, I was playing NCAA March Madness. The system shutdown in the middle of the game! There was no power...
It sounds like the power supply might be damaged.
Return it to Sony. If it is still under warranty, the repair will be free; otherwise, Sony will charge a flat $150 fee.
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Acer laptop aspire 4710z config my notebook have problem
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Nov 09, 2007 | Computers & Internet
Shut down
The best thing you can do is to reinstall windows. This will surely fix the problem.
Jul 26, 2007 | Acer Veriton 5600G PC Desktop
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
