Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Duet dryer The light stays on even when the door is closed but the dryer won't start. It's like it thinks the door is open. Can I try fixing this myself?
  • Anonymous Aug 14, 2008
    i have the same problem dryer is just 5 mon.old
    Sergeant:
    Champion:
  • 359 Answers
Yes, it may be as simple as a broken clip where the door opens & closes
Posted on Jun 02, 2008
How do I know the door switch is bad
If light stays on when fully closed, door switch needs replacement, easily removed. Short term fix, disconnect the switch and tape the two spades together. Warning! Dryer will run even with door open.
Nov 29, 2014 | Sears Kenmore Elite Electric Dryer 69278
When i push and hold the start button the timer light flashes but it doesn't start. the interior light stays on even when the door is closed. door switch maybe???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore dryer doesn't recognize when the door is closed.
first try unpluging the dryer for 5 minutes and then check it,this resets the computer board just like your house computer or you could have a bad door switch or something wrong with the main board,the main board is alot more than the door switch,if you have a meter you can read out the door switch,there should be a tech sheet in the dryer maybe taped to the side wall behind the bottom panel that might help you out.
Jan 14, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Dryer won't start; light stays on whether door is open or closed.
Sounds like the door switch is not functioning or shorted......in other words the dryer thinks the door is open so it won't turn on.
Jun 22, 2009 | Dryers
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
159 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
