Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
The cassette door will not shut when I put a tape in it. It will shut when there is not a tape.
    Genius:
  • 1,812 Answers
This is usually caused by a defective component in the tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 18, 2010
4 Suggested Answers
  • 883 Answers
SOURCE: machine just shut off when opening the cassette door. Locked up!!
look for a tiny pinhole and insert a pin while powered up to reset the device
Posted on May 27, 2007
  • 34 Answers
SOURCE: Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
Posted on Sep 05, 2008
caroldon
  • 17130 Answers
SOURCE: I have a Samsung SD263.
There is a fault in the loading mechanism that has resulted in the mechanism being out of alignment or failed.
If you hear any motor noise as you switch on the camcorder then the problem is related to failure of link of the loading mechanism , can be a gear , belt or pulley that has slipped off.
However if you do not hear any noise then the possibility of failure of the motor drive, driver circuit- loading IC- or the motor. Now this needs a technical check of the voltages to the circuit to confirm and you must be versed with basic electronics and some mechanical skills, so as to remove carefully the panel , boards and check the mechanism.
In fact it is no as easy as mentioned above but the work needs good attention and skill to infer.
Posted on Feb 23, 2011
Cassette door will not stay shut
yep thats the camera telling you that its broken or that the tape is damaged
Nov 01, 2014 | Samsung VP-D103i Mini DV Digital Camcorder
I have a sony cassette deck tc fx44. If I try to insert a cassette am unable to close the door. The door closes just fine without a cassette
Sometimes the tape sensors or record sensor gets bent or out of place so the door wont shut. Look for something like that.
Mar 30, 2013 | Audio Players & Recorders
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
The door those not close when I put a cassette in it. I closes normaly without a tape. Does anybody know this problem ?
alot of cassette tape deck doors actually come off, they clip onto the inner door assembly, if the outer part isnt clipped on correctly, it may shut without a tape, but not with a tape inserted, try to see if the outer door is clipped on there correctly, jim d
May 07, 2011 | Audio Players & Recorders
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Error code
I believe this means that there is condensation in the tape mechanism.
Apr 06, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Feb 04, 2008 | Audio Players & Recorders
Machine just shut off when opening the cassette door. Locked up!!
May 27, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
