Question about Sanyo Xacti VPC-HD2000 High Definition Camcorder
FIRMWARE for Sanyo xacti vpc-hd2000!? - Sanyo Xacti VPC-HD2000 High Definition Camcorder
  • 3 Answers
Updating Firmware on Xacti HD2000
This page explains how to download and install the firmware update for the VPC-HD2000.
  • This firmware is for the VPC-HD2000 only. Please do not install it on another model.
  • By installing this firmware Greek, Swedish and Finnish will be added as new menu languages. (Please notice that for this purpose the menu languages Traditional Chinese, Simple Chinese and Korean will be deleted!)
    It is not necessary to install this firmware update when there is already the possibility of choosing Greek, Swedish or Finnish as menu language! Please check this before continuing with the update.
  • Before updating the firmware, please read through the explanations on this page.
  • Make sure to update the firmware in the order shown below.
  • The camera might not boot up properly if its power is turned off during the firmware-updating procedure.
  • Please read the accompanying licensing agreement before downloading this firmware. Downloading the firmware automatically implies your acceptance of the licensing agreement.
Requirements:
  • SD memory card (henceforth referred to as "card") with capacity over 8 MB.
  • Fully charged lithium ion battery.
  • Additionally, you need one of the items listed below:
    (i) A SD memory card reader (henceforth referred to as "card reader")
    (ii) A dedicated USB interface cable (shipped with the camera).
CAUTION
Be sure not to take out the battery during the updating procedure (this lasts about 60 seconds).
Avoid operating the buttons on the camera or closing the monitor unit during the updating procedure.
I) Preparing to update (copying the firmware onto a card)
Step I.1: Format the card on your camera*
  • Turn the camera on and set the "REC/PLAY"-button to "PLAY"
  • Press the "MENU"-button.
  • Move joystick to the left and select "OPTION MENU 3".
  • Move joystick to the right and select "FORMAT". Press the "SET"-button.
  • Select "FORMAT". Press the "SET"-button.
  • Select "YES". Press the "SET"-button.
    *CAUTION
    If you format a card, all images and data stored on that card (whether protected or not) are deleted! Please be sure to move or copy important images and data to a PC or to another card!
Step I.2: Download the Firmware*
  • The firmware can be downloaded here.
    icon_dl1.gif Firmware Update XACTI HD2000
    s313n081.bin (7.5 MB)
    *CAUTION:
    Please be sure to download the file onto a hard drive and not onto a removable location such as a card reader.
    The firmware file should be saved in a location where you can easily find it again later (e.g. save it on desktop of your computer).
Step I.3: Copy the file "s313n081.bin" to the formatted card (from step I.1):
The method of operation differs depending on whether you use a card reader (i) or a dedicated USB cable (ii).
(i) When you copy the downloaded files with a card reader: (1) Put the formatted card from step I.1 in the card reader. (2) Copy the "s313n081.bin" file created on your hard disk in step I.FIRMWARE for Sanyo xacti vpc-hd2000!? - firmware_hd2000_1.jpgry of the card.
(ii) When you copy the downloaded files with a dedicated USB cable: (1) Connect the camera to your PC with a USB cable and turn on the camera. When you connect to your PC, please make sure the camera's USB interface is set to "Card Reader". (Please refer to "Setting the Connection Mode" on pages 7 to 8 of the Instruction Manual in the Xacti Software CD 1.0) Please make sure the camera is recognized as a removable disc. (2) Put the formatted card (from step I.1) in the camera and then copy the "s313n081.bin"-filFIRMWARE for Sanyo xacti vpc-hd2000!? - firmware_hd2000_2.jpgd disk (in step I.2) to the root directory of the card.
(3) Remove the camera from computer.
Please read "Dismounting the Camera" on pages 9 to 11 of the Instruction Manual in the Xacti Software CD 1.0 for a description of how to disconnect the camera.
II) Updating firmware on the camera itself
CAUTION>:
Do not turn off the power during the updating procedure (this lasts about 60 seconds)!
  • If the power is turned off during the updating procedure, the update may not be properly completed and the camera may not start up.
  • To prevent the battery from running out during the updating procedure, please use a fully charged Lithium ion battery.
  • Do not remove the battery during the updating procedure.
  • Do not operate the buttons on the camera or close the monitor during the updating procedure.
Step II.1: Insert the card with firmware-update file (from step I.1) into camera
Step II.2: Turn the camera on and set the main switch to "PLAY".
  • The playback screen will be displayed.
  • If the camera is in SIMPLE mode, switch it to NORMAL mode.
Step II.3: Press the "MENU"-button.
  • The menu screen will be displayed.
Step II.4: Choose "OPTION MENU 3"
Step II.5: Choose "FORMAT" from the Menu Screen, but do NOT go into "FORMAT"
Step II.6: Move joystick to the left for more than 2 seconds.
  • The update screen will be displayed.*
    *No Update Screen
    If the update screen is not displayed, it's possible that the update file was not copied onto the card. Please refer to "Preparing to Update" to copy the update file onto the card and follow the updating procedure once more.
    If the main switch is set to "REC", the update screen will not be displayed. Make sure the main switch is set to "PLAY".
Step II.7: Choose "YES" and press the "SET"- button.
  • Updating will start.
  • During the updating procedure, the screen will show the message, "LOADING. DO NOT POWER OFF", and the access light will flash.
    Please do NOT turn the power off during the updating procedure! (this takes about 60 seconds).
Step II. 8: When the updating procedure is completed, the camera will turn off automatically.
  • Please remember to format the memory card once more before using it again.
Posted on Feb 03, 2011
  • 4 more comments
  • zindu Feb 03, 2013
    hello could you upload the firmware please as the website not longer exzist i tried all website but no luck please uploaded i have 1.1 version thanks in advance or thanks for any onw will upload the firm ware
    please upload the firmware as the official sanyo website is no longer existed they sold out to panasonic please any 1 who have 1.2 version or later upload it thanks in advance
  • tonigsm
    tonigsm Feb 04, 2013
    send me your email and i will send it to you
  • Galaxy Feb 05, 2013
    I need to fix my hd2000 too. Please send the firmware to my box galaxyav@hotmail.com. Thanks in advance!
  • James Hugard Jun 03, 2013
    I'm also in need of the firmware update... risking a log of junk mail, here's my address: james_hugard at hotmail dot com.
    Found it here http://www.youtube.com/redirect?q=http%3... via a YouTube link herehttp://www.youtube.com/watch?v=rBtNH6pKH... However, as it turns out, it won't flash on my unit (thankfully!), because I actually have an HD2000A (with iFrames format), which is already a later FW version!
2 Suggested Answers
tkkjohn
  • 76 Answers
SOURCE: Short battery life when idle - Sanyo Xacti VPC-HD2000
Those types of cameras are no more really used... it is good to get a just normal cannon or sony camera... and you will be able to do wonders
Posted on Jan 14, 2010
The camera always forgets the date and time and I have to do it again and again at every switch on. Maybe it is a battery problem? Could you help us please ?
Mine does that if I do not get to the end of the set up process but if I finish set up, setting at least the date and time then (as you say, as long as the battery holds a bit of power) it will stop asking me.
Jun 16, 2014 | Sanyo Xacti VPC-HD2000 High Definition...
I need Sanyo Xacti VPC HD1000 LCD
http://www.fixya.com/support/t1813324-lcd_video_camera_not_working
Apparently you can take the LCD apart, look at the part number and order it online somewhere.
Try shopwiki.com
Feb 11, 2013 | Sanyo Xacti VPC-HD1000 Flash Media...
Firmware for sanyo e1292
I purchased (used) the exact same camcorder from eBay. It arrived. Same deal as you described - turn "ON" and white screen appears. SO, I went out and got a new battery. Charging it now, so I will let you know the result after charging. This is my LAST go around with this. Normally, I would never buy a camera from eBay, but I've bought so much other stuff I have not had an issue with (including new & used electronics.) Will keep you posted.
Feb 10, 2012 | Sanyo Xacti VPC-HD2000 High Definition...
I have a Sony HD2000 camcorder. When using it the other day the screen went white. On and off buttons still work but all I can see is white.
Jan 31, 2011 | Sanyo Xacti VPC-HD2000 High Definition...
Cant find my softwear for a vpc-hd2000 was not in box..now what
Does anyone have an updated link for this? I got "NOT FOUND" etc...
Jan 11, 2011 | Sanyo Xacti VPC-HD2000 High Definition...
Sanyo Xacti VPC-E1W dispay is black, no image
Is the camera on and does it have batteris fully or half way charged?
Apr 09, 2010 | Sanyo Xacti VPC-E1 Camcorder
Strange, mine lasts a very very very long time, but in a standby state (power on, just close the lcd lid). Have you tried to just keep it in the standby state? I will never turn it off unless I need to, like to change sd cards, because it is super quick to capture video and it does not kill the battery.
I have 2 of these dual cameras and John is quite right, the Sanyo HD2000 is not a "normal" camera, its quite abnormally exceptional and way ahead of its time! Having a f1.8 lens, 1/2.5" cmos, 1080p @ 60 FRAMES/second, really makes it not "Normal". You will need a better computer to process the crazy 1080p/60fps images.
Jan 14, 2010 | Sanyo Xacti VPC-HD2000 High Definition...
Wrong battery charger in box
Radio Shack   I have a Xacti HD2000 and it shipped with a Sanyo VAR-G9 adaptor.  The RadioShack replacement is a P/N 273-1696.
There is a switch that must be set to +5V on the unit, and you need to match the assorted tips that come with the unit to the one you need for your camera.  On my HD2000, the "+" side is on the tip, but this is on an image on the back of the AC adaptor
Look for a diagram on the back of the adaptor you have. There will be two diamond boxes  one on the left with a '-' and one on the right with a "+"   and the diamonds will be connected to semi circles. The inside semicircle is the "Tip".
In my case (Sanyo Xacti HD2000)the "+" is connected to the dot in the center, so I have to align the "+" symbol with the word "tip" on the end of the Radio Shack cable.
(If this gets plugged in backwards... you can fry the camera).
Hopefully someone at Radio Shack can help you set this up properly.  That way you don't have to mail-order and wait long.
Apr 29, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
the driver is not separately available for Sanyo VPC-E760
Aug 06, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Apr 10, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Sanyo Xacti VPC-HD2000 High Definition Camcorder Logo
3,363 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
