Question about HP LaserJet 2420 Printer
My HP 2420 had a paper jam. I played around with it and must have cleared the path although I did not see any paper particles fall out. (I did have a jam and figured a small piece must have been left behind) However, now the problem is that it is printing blank pages. The old toner prints smudges: the new toner sends clean pages through. Either way, the pages are blank. The printer worked fine before the jam. I must have knocked somehting out of line or something is not snapped back in correctly or something silly like that. Any ideas?
  • 9 more comments
  • tballone
    tballone Oct 15, 2010
    Try and print a configuration page click the menu button arrow down to information click the green check button arrow down to print configuration page(s) hit the green check does that print out blank as well?
  • josiessong
    josiessong Oct 15, 2010
    Yes, I tried to print from the printers menu and it prints blank. That is why I think it is a mechanial problem.
  • josiessong
    Yes, I tried printing from the printers menu and it came out blank. That is another reason I think it is mechanical.
  • tballone
    Try to print a engine test page the button is located on the the formatter near the front of the machine
    Remove the cover that is located next to where you plug-in the the usb/ lpt cable and you will see a little black button toward the front of the machine. it should print a page with vertical line lines.
    to get a better idea of where I''m talking about use this link it's a pdf file which shows you where the formatter is http://printersupport.rbizsolutions.com/...
  • tballone
    From the Manual:
    To verify that the printer engine is functioning, print an engine-test page. To print an engine-
    test page, press the engine-test-page switch on the formatter (see callout 5 in Figure 7-8.
    Sensors and switches, HP LaserJet 2400 series).
    The test page should have a series of vertical lines. The test page prints from the last tray
    that you used to print unless the printer has been turned off, and then turned on again since
    the most recent print job. If the printer has been turned off and then on again since the most
    recent print job, then the page will print from tray 2. The printer will continuously print test
    pages as long as the test-page switch is depressed. The printer will not print a test page if it
    is in Sleep mode.
    A damaged formatter might interfere with the engine test. If the engine test page does not print, try removing the formatter and performing the engine test again. If the engine test is
    then successful, the problem is in the formatter, the control panel, or the cable that connects
    them.
    Let me know your outcome.
  • tballone
    sorry link did not show up correctly:http://printersupport.rbizsolutions.com/...
  • tballone
    the system keep rejecting the link for some reasonhttp://printersupport.rbizsolutions.com/... then click on Formatter from the list of items.
  • josiessong
    josiessong Oct 16, 2010
    Hummm, I have studied the diagrams but I can't seem to find the test switch. I thought it appeared in the diagram in the area of the battery....I had problems finding the switch on a hp2200 so I thought I had an idea what I was looking for but apparently not.....any hints on finding it? Isn't it just a flat black square switch sitting on top of the board? Thanks for your help.
  • josiessong
    tballone- Thank you so much for your help. I have fixed the problem. Inside to the left side of the toner there are 3 springs. One of the springs was "knocked" out of alignment. Once replaced back into its track the printer printed fine. Thank you for your time and help. ---Lori
  • josiessong
    How do I give you an "asker rating"? --Lori
  • josiessong
    josiessong Oct 21, 2010
    michelsmith:
    Thank you for the advice. My printer is a basic laser printer with only a black toner. I figured I must have knocked something out of line while trying to see if a small piece of paper was blocking one of the paper sensor switches....it in the end it was something I caused by knocking a spring out of its track. Thanks again and I hope someone else searching for a solution finds this helpful.
    Scholar:
  • 126 Answers
From the Manual: To verify that the printer engine is functioning, print an engine-test page. To print an engine- test page, press the engine-test-page switch on the formatter (see callout 5 in Figure 7-8. Sensors and switches, HP LaserJet 2400 series). The test page should have a series of vertical lines. The test page prints from the last tray that you used to print unless the printer has been turned off, and then turned on again since the most recent print job. If the printer has been turned off and then on again since the most recent print job, then the page will print from tray 2. The printer will continuously print test pages as long as the test-page switch is depressed. The printer will not print a test page if it is in Sleep mode. A damaged formatter might interfere with the engine test. If the engine test page does not print, try removing the formatter and performing the engine test again. If the engine test is then successful, the problem is in the formatter, the control panel, or the cable that connects them. Let me know your outcome.
http://printersupport.rbizsolutions.com/hp-2410-printer-support.html#replacement then click on Formatter from the list of items.
Posted on Oct 19, 2010
  • 1,218 Answers
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Posted on Oct 21, 2010
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Paper jam, clear jam and then press enter but there is no paper jam in printer
There are several sensors along the paper path. There could be a small piece of paper on one of them. You can use a can of air to blow it out. The quality of paper you use can leave small pieces of paper all around.
Sep 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
WE HAVE A PAPER JAM ON THE BACK FUSER OF HP LASERJET 2420. A PIECE OF PAPER IS COMPLETELY WRAPPED AROUND IT.
You can attempt to remove the fuser from the machine to have better access to the paper inside. It is very easy to damage the fuser roller and film when removing a piece of paper wrapped around inside.
We recommend calling for service, but worst case is you try yourself and can't get the paper out then you would just order a new fuser.
We can get you the fuser. Just call 262-993-1551. We offer free shipping.
Sep 02, 2010 | HP LaserJet 2420 Printer
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
I just changed printers cause my printer kept jamming it is a hp laserjet 2420 the same printer that I had before and my computer isn't recogonizing it nothing prints now.
next time play around with the paper jamming is caused by the loading of the paper just adjust it by hand,square it up etc,dont just put paper in the tray and leave it,these machines would have to be extremely sensitive to be able to load correctly every time,i dont know why the same model isnt working
May 21, 2010 | HP LaserJet 2420 Printer
Blank printing
Did you pull the plastic tape from the side of the cartridge?
Nov 14, 2008 | HP LaserJet 2420 Printer
The paper is constantly getting jammed in my hp psc 1510 printer
Ok...possible problems and solutions:
1. Most likely there is a small particle of paper still in the path which continues to pick at one of the new pieces of paper's edges and causing the new jam. Solution: check every crevice of the paper path for small bits of paper and remove.
2. the paper is too light for this printer. Cheaper paper is lighter in weight and typically will "ball up" easier with the action of the print head accross the sheets. This is why you souldn't use "copier paper" in your HP inkjet printers but it might be alright for the laser ones.
3. a previous jam has damaged (bent) one of the precision guides or parts in the paper path. Solution: buy a new printer.
4. the paper is too thick for this printer...(doubt this is the case but thought I would mention it) Solution: use lighter weight paper.
Jun 22, 2008 | HP Office Equipment & Supplies
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Feb 20, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
1,025 people viewed this question
Seeker5211
Seeker5211
