Question about Sony Playstation 3 (PS3) Console
My ps3 recently got the yld and i looked up how to fix it myself. i took it apart cleaned it of all dust and applied the new thermal compound and everything else that your supposed to do. After i put it all back together i turned it on and when i hit the on switch in the front the light turns green yellow green again and then finally starts blinking red and thats it. The fan starts to run but by the time the light is blinking red it stops.I read somewhere that taking out the hard drive a couple times should fix it but for me it didn't work so someone please explain to me whats wrong and how to fix it
  • 104 Answers
Almost 90% of ps3 can be fixed by new thermal Compound but you may need a new power cord either way id just send it to sony but im glad u tried i failed too trying to fix mine
Good Luck and Happy Gaming-Koscoe
Posted on Oct 15, 2010
HELP... I have a big problem with my PS3. My system was okay when I took it apart for cleaning but i completely disassembled it and cleaned the dust. I put it back together and now it wont work! When I...
I fix PS3 Yellow Light of Death.
When you say you completely dissasembled it i guess you mean EVERYTHING?
Well did you make sure you plugged the battery back in? and Made sure all connections were placed back?
If you took off the heatsink and fan from the chips then that is why it switched off!
You should have put new paste on if thats the case!
The PS3 seems it is shutting down to protect itself from overheating and burning the chips!
The baby scratch should be ok unless it has destroyed a copper track?
Goodluck let me know how it goes and please rate!
Apr 08, 2011 | Video Game Consoles & Games
On my 60gb ps3 I was having problems with it freezing after 10-15 mins of gameplay on the loading screens, I have had it since around 2006 so my warrinty was up. I took it apart and cleaned all the dust...
Hi Max,
If your PS3 is freezing up then you need to stop the heat build up internally and to do this you will need to get it repaired.
Now you can send it in and they will fix it for you that is the standard method however bear in mind that there will be a repair charge of $150 for the fix which is quite steep!
The other way that you can fix it is by using a good PS3 Repair guide.
Just a quick word of advice though, make sure you check out these reviews of the top guides so you can be sure what they offer.
Click Here To See PS3 Repair Guide Reviews
Hope this helps.
Mar 31, 2011 | Sony Playstation 3 (PS3) Console
Thermal event but fan is working
It could still be overheating from dust and old thermal compound.
You should clean the inside of the computer with compressed air outside and make sure you're running the latest bios firmware for your board. If the problem persists I would think about applying a new layer of thermal paste to the cpu / cpu fan.
Hope this info helps!
Dec 31, 2010 | Dell (C2057) Motherboard
I have the ylod. What do I do?
This happened to me yesterday. I took the unit out, unplugged it, placed in face down in a box and blew hot air from a blow dryer through the back vents for 15 minutes. I then placed the unit with the back vents face down on top of my a/c duct for 30 minutes and it works again! Its worth a try before trying to disassemble the unit.
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Trying to update my ps3 and it keeps saying error 80710723 wot can i do
My 80gb ps3 did the same exact thing. I kept trying to get to install, but it just would not. called SCEA and they told me i'd have to send it in and pay about $200.00 for a refurb. So, i completly took it apart. Cleaned every thing, put new thermal compound on it. AND, presto install completed now i can use my ps3. Did not reflow just cleaned and new compund. And learned I should just update using USB flash drive. Works like a charm. Good luck. Hope this helps.
Apr 01, 2010 | Sony Playstation 3 (PS3) Console
Hi ive just turned my ps3 on it stopped and went off now it wont play just got a red light when pushed it flashes green and blue the goes red when pushed again it flashes red help
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
My cpu overheats
clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
Oct 25, 2009 | Gateway 504GR PC Desktop
Ps3 shuts off during gameplay
My PS3 shuts off 15 minutes after I play can I fix the problem in system settings
Mar 25, 2009 | Sony PlayStation® 3 (60 GB) Console
Playstation 3 overheating Fan problem?
I have done the research!!! And I wrote this guide taking more safety precautions against breaking my system than the originators so this is a reproduced guide wearing safety belts.
This means there are 2 possible problems with your PS3. Either 1) your fan is dying and needs to be replaced or 2) the heat transfer from your 2 processors to the fan is deteriorating. Number 2 is the most popular for overheating because Sony didn't use the greatest of thermal compounds on their processors, and the heat sink solutions Sony used in its launch systems weren't as well engineered as the later systems. 60gig are the most prone.
This has happened to me and I have fixed my PS3. It works perfectly as if I had just bought a new one (fan is super quiet, showing that the heat transfer is working perfectly) and 5 months later I had to repeat the process and it fixed the problem again. So, this solution may have to be an ongoing task through the years, I suggest doing it 3 times a year like I plan on doing. All you need is a couple screwdrivers, thermal paste (preferably something with silver or more expensive, Arctic Silver is good), and a heat gun (usually made for stripping paint) that gets to at least 650F. The processors in this MB are soldered in...
Okay, assuming you are good with handling hardware and get the PS3 bare down to its motherboard, you should see the huge *** fans mounted to the 2 processors, 1 says GPX and the other CELL I think.
1- You need to take off the fan carefully 2- Clean all the dust you can possible see, CAREFULLY 3- Use acetone or some other 99% alcohol compound to clean the old thermal paste off the back of the processors and the mounts of the fan. --------------------------------- This part is important --------------------------------- 4- Look for the 2 black chips that are almost touching each processor above (or below depending on the direction the board is) and pay attention to their location to the chips for when the board is upside down.
5- Place your motherboard on a flat, heat resistant surface and set up to where nothing will touch it for 30 minutes.
6- Using the heat gun, heat the processors for 25 seconds a piece (less time the hotter the gun) using a circular pattern as not to have the heat focused in 1 spot. Then do the same for the 4 black chips.
7- Let the motherboard cool for 30 minutes. You will hear popping noises, this is the solder hardening back up after being set further in its socket. DO NOT TOUCH MOTHERBOARD. It is hot and any outside pressure or contact could snap it. Just let it sit there.
Whats happening is your are resetting any connection damage that might have occurred from the processors getting hot and not cooling properly. This also corrects any minor misalignment of the processor and its seat.
8- Flip the motherboard over and repeat steps 6 and 7.
9- Now apply a thin layer of the thermal paste on the back of each processor. Just enough so you that appears like you can see through it. Not literally but to the point that you think you can make out a letter on the processor.
10- Mount the fan back on carefully and clean up all excess thermal compound that may have been squeezed out the sides.
That should do it. Put the PS3 back together, leave the final screws unscrewed, hold your breath, pray to your deity and turn it on.
Like I said earlier, this happened to me I. I did this fix, failed because I didn't heat the processors long enough. Increased my heating time by 15 seconds each processor, and then my PS3 ran faster, smoother, and quiter for about 5 months before I had to do this fix again because my girlfriend doesn't like to turn my PS3 off (have to shorten auto shutoff to 1 hour now *sigh*). But fixed for a second time with same results.
Good luck gents. This solution does work, but you must also know that it may void the chance of Sony fixing this for you for 150. I paid $7 (US) for the thermal compound and $25 for the heat gun. And the PS3 are $300
Nov 30, 2007 | Sony Playstation 3 (PS3) Console
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Sony Playstation 3 (PS3) Console Logo
121 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
