Realtec RTL 8168D/811D wireless adapter, Plantonics DT12 (2.4MHz) Cordless Phone, Magic Jack, Windows7. Phone works intermittently in different ways. Sometimes caller can't hear me, sometimes call doesn't go through, etc. Plug MagicJack into standard Trim-line phone and MagicJack works perfectly. I assume it's interference from Wireless adapter. I also assume that it might be a channel issue. Again I assume that the Plantonics phone is on Channel 11 but I don't know what channel the wireless adapter is on, or if this will be the fix
One Piece
  • 53 Answers
SOURCE: Interference from 5.8 GHz cordless phones
also try changing the wireless channels to 11 to reduce interference to 3rd party hardware such as cordless phones, and power settings should be 10 to ensure modem is broadcasting at full 400mW of power. do not put the modem near your cordless phones, and it must be sitting upright.
Posted on Apr 03, 2008
SOURCE: vtech cordless phone appears to be mute
does anyone out there have a solution for peggy's problem? I have the same problem------Bob
Posted on Jan 12, 2009
SOURCE: Magic Jack will not initialize , however the demo for magicjack r
After 2 days of frustration I was able to solve this by the following:
1. Click Start
2. right click my computer and select properties
3. select hardware then Device Manger
4. click + DVD/CD-ROM Drives
5. right click Tiger Jet CD-ROM USB Drive then Uninstall
6. unplug Magic Jack wait 15 secs
7. Plug back in and let device re-install, MJ may start here, if not...
8. Click Magic Jack Icon, program should start
I have to do this everytime I unplug or restart my computer. I don't know exactly why it hangs like this but this procedure works for me everytime. Good Luck
Posted on Mar 08, 2009
  • 4 Answers
SOURCE: magicjack does not recognize my phone
"However the phone option is not available..." Are you sure? you can switch to headset or by phone anytime you want. Switching to either one of these devices you need to right click on your magicJack phone number in the software(located at the top left portion) and click on "switch to phone/telephone".
Posted on Apr 20, 2009
SOURCE: MagicJack caller ID issue
I found this solution. It worked...
Posted on May 24, 2010
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Dec 10, 2014 | VTech Communications Cs6124 Cordless Phone...
My magic jack plus will not work and I am wondering if the electrical connector is bad.
Go to the magic jack website and update your adapter. Also try different USB ports and reboot your computer with magic jack connected. If the computer does not recognize the adapter, try disconnectin and reconnecting into different ports. There is a update option on magic jack website and tech support as well.
Nov 04, 2014 | magicJack PLUS VOIP Phone Adapter
Connect magic jack
Feb 01, 2014 | D-Link Dlink Dir-615 Cable/dsl Router...
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Panasonic 5.8ghz cordless phone, caller id does not work with Magic Jack plus, only the person phone# comes up twice
The phone will only show the information that it is given by your phone service provider (Magic Jack).
Oct 31, 2013 | magicJack Two, 2 Magic Jack Plus Voip...
Calls cutting out with magic jack
Your ISP connection speed may be inadequate. Typically, the upload speed (outgoing voice) is much slower than the incoming speed. To check majicjack recommends that you test your system on .
It's also possible that your internet provider is purposely delaying the outgoing latency in order to discourage VoIP that THEY don't provide. I think this is (or at least should be illegal) but in any case a complaint to the FCC might be in order.
Aug 23, 2009 | Computers & Internet
MagicJack VOIP sound cuts in and out
Try your magicjack device in another usb port, as they sometimes share an irq internally with other devices, hence the chopped sound. Also make sure your computer is no trying to go into sleep or suspended mode, check the power settings to make sure the system is not shutting down devices in low power or battery mode if using a laptop, make sure the connection speed is good and strong, especially if connected to a laptop, and make sure nothing is hogging the cpu, causing the chopped sound. Also there could be issues with the router. Lastly, perform a firmware upgrade on your magicjack device, restart the machine, and then test it again. Good luck.
Jun 12, 2009 | Computers & Internet
I have a usb100 wireless adapter on 2.4 frew my cellphone are on
This is a classic interference problem for wireless routers and adapters (specially if both your phone, wireless router and adapters are on the same frequency - say 2.4Ghz).
What we can try first is to change the channel on your wireless router. If you can specify the model/brand of your router I will be able to give you the specific steps in changing the wireless channel.
Second solution would be to move the wireless router and the base station of your cordless phone away from each other.
Third solution would be to replace the cordless phone with a unit that uses a different frequency (say a 5Ghz phone).
Regarding your USB wireless adapter, well it's just a receiver of a signal and there is nothing we can change on that device to resolve the problem. This is a problem between your wireless router and your cordless phone.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Computers & Internet
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
