Question about Belkin (F5D7231-4) Wireless Router
I have had the router for over a year, it has now does not connect to the internet and the internet icon is flashing yellow please help
    Brigadier General:
  • 10,406 Answers
Disconnect the AC power.
Wait a few seconds.
Reconnect the AC power.
If the same problem appears, it's time to spend $20 to $40 to upgrade to a new "Wireless N" router (faster, stronger).
Posted on Oct 15, 2010
Hi...i have a problem...pina reformat q laptp q ang then after that hindi na aq mka internet through dsl q...wat shud i do??? cannot connect to the internet dw eh sa lan q connected nmn...pano to???
english please . . . .
1st check your driver manager to know your all driver are correctly install , ,
just right click/mouse2 on computer icon and select manage, ,
it will apear on your screen the new window, then click device manager make sure that there's no yellow icon question mark. . yellow icon mean's driver are not install ,
2nd: if you don't know what driver you had to be download post *********** board model here, in that way we can help you. . . .
Apr 20, 2011 | Computers & Internet
Hello. I have a Dlink dir 600 router and it worked without problems for about a year (usually there were 2-3 laptops wirellesly connected to it). Then suddenly I couldn?t connect to the internet anymore....
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 13, 2011 | D-Link DIR-600 Router
Belkin f5d8233 is flashing yellow modem light ..is not connecting?
Hi Friend,
Please check whether you are able to connect to the internet when the modem is directly connected to any of your computer.
If you are not able to connect to the internet please check with your Internet Service Provider
Regards,
Aysaam
Apr 12, 2010 | Belkin (F5D5231-4) Router
My router won't link up to my modem. I have a
make sure that you ethernet adapter is enabled. you should be seeing a two computer icon in the notification area. reinstall driver of your eternet adapter.
Apr 01, 2010 | Powerline Ethernet Network Adapter
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless switch not working
Sometimes when you bootup and the error message = "wireless connection has limited or no connection", or has a red X on the wireless icon, it is because the router has not issued an IP address to the wireless card. Right click on the wireless connection and then click Repair.
If this doesn't work then reboot the router then the laptop, this should fix the problem
Sep 02, 2009 | Computers & Internet
I have netgear WGR614 it wont conect to the acual internet only local the wirless light isnt flashing green its blinking yellow
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Jul 09, 2009 | NetGear WGR614 Router
Flashing image on the Display
Icons from left to right:
The world: The Internet, if blinks there's not connection.
The modem: Your ADSL/Cable modem attached to the yellow RJ45 port
The router itself
The computer: All the attached computers to the grey RJ45 ports
The WL computer: All the computers connected via WiFi
The lock: Means that there's WiFi security enabled
Jan 02, 2009 | Belkin N1 Vision Router
Belkin (F5D7231-4) Wireless Router Logo
27 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
