Question about Ovens
355 Fridigaier manual - Ovens
    President:
  • 2,777 Answers
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.frigidaire.com/files/pdf/318203821en.pdf
Thanks,
Tim
Posted on Oct 15, 2010
Kitchenaid superb microwave.oven combo KEMC308KSS0 is giving F2 E0/E1 error. Replaced the switch membrane and also the Control board. The error still shows up.
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
Apr 15, 2017 | KitchenAid Ovens
Where can i buy a replacement control display
Hello Friends!
This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too.
Apr 13, 2017 | DCS Ovens
Error code F2 EO oven not working
Nov 16, 2015 | Ovens
SC302TS. Why won't oven heat?
If it's not the thermal fuse, it is often a control board failure. These boards are no longer available from the mfr but can be rebuilt at:
http://www.fixyourboard.com/boards/14-38-901.html
Often the relay boards need work too. We can rebuild these as well. Just contact us at FixYourBoard 512-355-1108
Aug 11, 2015 | Thermador Ovens
My clock changes time at will. It jumps ahead minutes, then hours. Can I fix it?
Most likely you need your control board rebuilt. You can contact www.fixyourboard.com at 512-355-1108 or info@fixyourboard.com for a quote. Please provide your model number with contact.
Aug 07, 2015 | Ovens
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
What does error code F1 E1 mean on a kitchenaid built in oven?
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
Note: Applies to all F1-E...
codes except F1-E3.
Feb 14, 2011 | KitchenAid KEMC378 Electric Double Oven
The top display says F2:E1 and the oven won't function. How do I fix this?
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
Nov 04, 2010 | KitchenAid Architect Series KEMC308KSS...
Error code EO -F2- Any one know what this means
May 29, 2010 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
71 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
