Question about Clarion CZ100 Car CD MP3 Player
Set the clock on clarion cz100 car radio - Clarion CZ100 Car CD MP3 Player
  • 142 Answers
SOURCE: how to set the clock on a clarion DB175MP
http://www.clarion.com/us/en/products/2007/audio/source_unit/CD/DXZ275MP/us-en-product-pf_1165294998468.html
Go the link shown above. On the right side of the screen, you'll see a button to download the product manual. Download the manual in PDF form, and go to page 19 where you'll find the step by step on how to set the clock.
Normally I'd write it out for you, but there's a lot of symbols to describe the buttons, and the information is copywrited. At least you'll have the manual.
Posted on Mar 14, 2008
SOURCE: clarion drb4475 set the clock
Found this elsewhere on this site:
To set the clock, press and hold BAND and DISP to display the clock. Press and hold BAND and DISP until the display flashes. SEARCH left to adjust the hours; right to adjust the minutes. Press BAND to set.
Posted on Aug 18, 2008
DrWho_64
  • 35 Answers
SOURCE: clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Posted on Jul 09, 2009
SOURCE: Clarion ADX 5355 Addzest, fm freq won't go past 90, clock reset
This is a unit for the japanese market and they only use bands 79 to 90. You can install an FM band expander, available on Ebay for about £5, and get loads more stations. The expander is easy to fit if you can get to the back of the radio, it fits in the aerial lead and needs a 12 volt connection. Some people reckon they work well others don't rate them, probably worth a try at the price they are.
Posted on Jan 23, 2010
  • 239 Answers
SOURCE: Clarion CZ100 install ?
yellow battery
red accessory
black earth
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
Posted on Aug 19, 2010
I have the manual for the Clarion NX501, but it does not tell HOW to set clock.
Page 51 of the manual, under General Setup Menu, is Clock.
Here is where you set time, AM/PM, or 12/24 hour clock,
Nov 02, 2015 | Clarion Car Audio & Video
What is the pinout orderfor clarion cz100
No idea.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Oct 21, 2015 | Clarion Car Audio & Video
Where do i hook the brown wire to clarion cz100
The brown wire is probably phone mute. You don't really need to attach it to anything for the radio to work.
Dec 04, 2011 | Clarion CZ100 Car CD MP3 Player
I Have A Clarion CZ100 On My Integra, I Put It Back On Yesterday Because My Car Came Out of The Shop. It Was Doing Fine Until Today, Turn On My Car and It Played, But When I Wanted To Change The Radio...
it's more likey the faceplate, and where it makes contacts with the unit. if you try applying pressure and moving the detachable faceplate on while attached and it turns on, there could be a cold solder/loose connection on the board.
Feb 06, 2011 | Clarion CZ100 Car CD MP3 Player
I have a clarion cz100 hooked up to a 1000 watt autotek amp and it is connected to a red top optimum battery. When i turn it up to BUMP it if im not moving the stereo will shut off. I had it hooked up to a...
some stereos will shut off if the voltage drops below 12 volts. measure your voltage at the battery with the car at idle and stereo turned up and all accesories and lights on. you should have 14.4 volts with the car running. the batteries voltage is 12.6 volts so you have to have more than this to be able to maintain steady voltage to your components. if the voltage drops too low when the bass hits it can shut off your radio. a capacitor can help this and the safe number is 1 farad for every 1000 watts. if you plan on adding any other amps autotek and phonix gold both make a digital capacitor that is compact and go anywhere from .5 farad to 10. the bigger the cap the better. if your voltage readings are ok then check that your speaker output wires are not touching.
Dec 23, 2010 | Clarion CZ100 Car CD MP3 Player
Installed cz100 radio sounds great, cd loads & reads but no sound???
are you using an amplifier? if so, it sounds like you are using the blue (antenna remote turn on) wire instead of the blue/white (amp remote turn on) to turn the amp on.
Nov 16, 2010 | Clarion CZ100 Car CD MP3 Player
yellow battery
red accessory
black earth
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Aug 10, 2010 | Clarion CZ100 Car CD MP3 Player
Set clock on m2455 radio/cd
since i don;t know which version you have of that unit here is a link with manuals just pick the version and it will tlel you how to set your clock.
Clarion
Mar 26, 2010 | Clarion M255 AM/FM Marine CD Player
How do you set the clock on a clarion car radio model RAB030F
Setting the CLOCK- CLARION RAB030F
1)Turn the Power on.
2)Press and hold the BAND button a,while
again. pressing the Function button 4 to enter to clock setting.
3) Use the volume, Up and Down buttons to adjust the clock .
4) Press the BAND button to exit
Grettings from Per?, South America
Gian Carlo Scarpati
gscarpatig@hotmail.com
Aug 15, 2009 | Clarion RAB030F
Arx 1970 car cassette
Setting the clock:
1.Press and hold the Band Button (on the left of radio)and the Clock setting button (button No:4 on the right) to display the clock.
2.Press and hold the Band button and the Clock Setting button again for 2 seconds or longer for the clock display adjustment.
3.Press the SEEK UP Button (on the right of the radio with the arrows) to set minute.
4.Press the SEEK DOWN button to set hour.
5.Press the Band button to confirm the clock setting.
Jul 11, 2008 | Clarion ARX6670Z Cassette Player
Clarion CZ100 Car CD MP3 Player Logo
434 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
