Question about Leviton Decora Light Dimmer Switch
My girlfriend has a leviton illumatech IP106 that keeps "not working". after a number of months. It is operarting a standard dining room 6 light chandelier. A couple of her friends have replaced this in the past...now its my turn. Upon inspection I noticed it was wired incorrectly. A red and black wire on the switch were wired to 2 black wires out of the wall with a wall red wire capped. I know little of houshold wiring but have an avionics tech background. One of the black wires has a potential of 122vac the other 7vac and the red is ground. I assume the swith black goes to 122vac and the switch red goes to ground. But there is an additional red & green on switch. The red is for three way installs (whatever that means). Does the green get used?
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Posted on Oct 15, 2010
Testimonial: "Thank you for the excellent advice!"
I want to build my own set of dining room chairs. Can someone recommend a good site to use with design templates?
I found you a site with designs for both standard dining room chairs and chairs with arm rests. Hope this helps you out.
http://www.freeww.com/diningchair.html
Aug 09, 2012 | Furniture
What is the standard height of a kitchen/dining room table?
Hi
I was looking for dinning room tables which were standard size and came upon an interesting page at Macy's. They seemed to over a variety of shapes and sizes, many of which will cater for your needs in the kitchen, or dinning room for that matter.
May 29, 2012 | Furniture
Changed out 3-way switch with 6633-p and it will not operate light. this is a 2 location 3-way being used on a dining room chandelier.
Look at 3-way drawing in 6633 manual.
Notice that device has to be installed to Hot wire.
Only one of your 3-way switches will have the Hot wire.
Change device with other 3-way switch.
Make careful note of which wire connects to dark-colored screw. This is the common screw.
Dec 29, 2010 | Leviton 604-6633PW Decora Slide Dimmer...
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Dec 22, 2010 | Leviton Decora Light Dimmer Switch
I hooked up the leviton IP106 dimmer switch for a single pole and when I test the it, switching it off and on it stays hot.
I'm assuming you've connected the line (hot) on the black and the load (out to fixture) to the red? So does the light stay on or your tester is measuring voltage. Some electronic controls will test voltage on a tester. if there is no load connected
Aug 03, 2010 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
How high should we install our chandelier over the table
It depends how high your ceiling is and the size of the chandelier. If your dining room is eight feet tall, hang the chandelier 27 to 36 inches above the table.
Visit www.metropolitandecor.com and ask their lighting experts for more info.
Jan 12, 2010 | American Standard 7048.203.___ Chandler...
Newly installed Leviton dimmer switch humming at the switch
Unfortunately, the hum is normal for operation of that type of dimmer at low levels.  Sometimes the lamp filaments will also "sing" a high pitched sound.
Mar 17, 2009 | Lutron #D-600PH-DK 600W SP Push Rotating...
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Leviton  Decora Light Dimmer Switch Logo
439 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
