Question about Vector Maxx SST Power Inverter
I have the Vector Maxx SST 500W Power inverter. I believe I may have inverter fuses open. How do I go about closing the fuses? Repairing this unit
3 Suggested Answers
duane_wong
  • 6826 Answers
SOURCE: i need help hooking my vector maxx sst 1000 w
A 1000 watt power inverter hooks to the battery terminals directly, not through the cigarette lighter.
Posted on Jul 20, 2010
  • 185 Answers
SOURCE: (Vector 400 Watt sst Power inverter) When I plug
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Posted on Feb 06, 2011
Do I need to put a inline fuse or does the vector sst 1200 have a fuse or breaker in it
It probably does, but an in-line fuse is still the safest way to go, connected as close as possible to the voltage source as possible. The internal overcurrent protection device (aka, fuse or breaker) in the inverter will prevent the DEVICE from melting if it malfunctions. An in-line fuse will protect EVERYTHING if the WIRING malfunctions.
May 05, 2014 | Vector ® Maxx SST 1200 - watt Power...
What size of fuse is needed for replacement
The fuse is 25 amp spade type and there are evidently two.
Apr 27, 2011 | Vector VEC024B MAXX SST Power Inverter
With the vector 2000 watt converter do you need to run 2 batterys.
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
Mar 06, 2011 | Black & Decker Vector MAXX SST Series,...
(Vector 400 Watt sst Power inverter) When I plug the Inverter into the Cigarette lighter of my RV, and the TV 26" into the inverter It won't work.
Feb 05, 2011 | Vector VEC024B MAXX SST Power Inverter
I have a Veco24B 400 Watt DC to AC inverter and the fuse that is suppose to be located in the cigarette lighter adapter is missing and I would like to know the size of fuse that is required.
I would put a 20 amp fuse in. The wiring for the cigarette lighter is usually around 15 - 20 Amps. The wiring also is not rated for more than 20A. I hope this helps. JOe
Dec 22, 2010 | Vector VEC024B MAXX SST Power Inverter
I CANNOT FIND A REPLACEMENT FUSE FOR THE VECTOR VEC024B INVERTER.i HAVE OWNED IT FOR LESS THEN 3 MONTHS . IS THERE AN ALTERNATE FUSE THAT CAN BE USED?tHIS IS THE CIGERETT LIGHTER CABLE FUSE. F8VL250V.
Go to any Appliance parts store with your fuse in hand and walk out with a replacement. The 250V fuse is AC OUTPUT and "not" a DC input fuse. That is an 8 amp 250V slow blow fuse.
Mar 23, 2010 | Vector Maxx SST Power Inverter
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Green light on but no ac power out
Probably has an internal fuse that is blown. You will have to disconnect it from dc power and take the cover off and look for a fuse that is blown, should be near the AC outlet or on the circuit board. Could be a glass tube or newer style automotive plug in type. Good luck.
May 18, 2009 | Vector ® Maxx SST 1200 - watt Power...
Vector Maxx SST Power Inverter Logo
64 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
