Question about Asko T701 Electric Dryer
I have a ASKO stackable washer dryer model T700 the dryer is not heating up, i get only cool air. I had someone look at it and he said i need a program control knob. I would like to know of a parts place located in the 33304 zip code i can recieve this part from?
  • Asko Master
  • 2,605 Answers
Hello, Welcome to FixYa. Based on your description I`d direct you to first check the hi-temp cut out at the back ( black rubber round button )...if you haven`t already. If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a plugged lint filter, plugged vent ot partially plugged or the heater itself is plugged up with lint. Take the lint filter and clean it under some warm water and soap as they do become plugged with wax over time due to fabric softener and static sheets. If it doesn`t heat after-wards or it`s not tripped, you`ll need to investigate for a faulty heater element. This is quite involved, so we`ll cross that bridge when you get there...if necessary. Keep me posted on your progress or what you find. Good luck. Regards, Macmarkus :)
Posted on Oct 15, 2010
  • Mark MacDonald
    Mark MacDonald Oct 17, 2010
    Welcome to FixYa.
    I wanted to re-post my solution because I didn`t like not being able to provide the images I typically do when answering peoples questions. I was away on a trip to Phoenix and only had my iphone.
    Take the lint filter and separate the two pieces and clean it under some warm water and soap as they do become plugged with wax over time due to fabric softener and static sheets.
    and
    If it doesn`t heat after-wards or the hi-limit is not tripped, you`ll need to investigate for a faulty heater element. This is quite involved, so we`ll cross that bridge when you get there...if necessary.
    Keep me posted on your progress or what you find. Thanks for choosing FixYa and good luck.
    Regards,
    Macmarkus :)
Asko t700 dryer schematic diagram
see the schematic attached. and fix it. Merry Christmas
Dec 18, 2013 | Whirlpool Dryers
I have a Asko dryer T700. Runs but doesn't. Vent not blocked, filter clean.
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 25, 2010 | Asko Dryers
I have a asko t700 it goes on drum turns but no heat when set at high or low heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Asko T700 Electric Commercial Dryer
Asko T700 dryer does not heat up, and start button does not work unless held down.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 07, 2009 | Asko T700 Electric Commercial Dryer
Asko 700 dryer was overheating sometimes even on low, now not heating at all.Starts, runs for a couple of minutes and shuts off
1) check and or clean you vent..
2) check air coming out of the vent...
a) if no air coming out or little amout of air ... check blower wheel ( remove toe panel. then remove blower cover.) wheel should be clean and clear ...
PS. there is a reset button on the back panel... black button about center..
hope it helps if NOT let me know more about your problem...
Sep 18, 2009 | Asko T700 Electric Commercial Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Aslo T700 Dryer Heats but won't dry.
TRY DISCONNECTING THE EXHAUST FROM THE BACK OF THE DRYER AND RUN ONE LOAD THROUGH IT. IF IT DRIES O.K., THEN YOU HAVE A RESTRICTION IN THE DUCT WORK.
Apr 07, 2008 | Asko T700 Electric Commercial Dryer
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Dec 24, 2007 | Asko T700 Electric Commercial Dryer
Asko T700 dryer
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Dec 10, 2007 | Asko T700 Electric Commercial Dryer
Asko T701 Electric Dryer Logo
312 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
