Question about Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher
Kenmore 16532 dishwasher,three years old. It has slowly gotten very noisy. I have stripped down everything I can access from the tub, including the chopper. I can't find any problem. It is quiet while the water is filling, but growls as soon as it starts the wash cycle.
  • tssherwood Oct 15, 2010
    Thanks ! I stripped everything out of the tub. The growling is still there. A new motor and pump is $180. I think I'll just run it until it quits, then replace the motor.
    President:
  • 662 Answers
It could be 2 things:
a) water obstruction in the spray jet ports causing uneven rotation of the spray arm.
This uneven rotation will eventually wear out the motor bearings.
Fix: clear out any clogged spray jet ports.
b) the motor bearing are already shot, and they're growling and howling in pain as the motor grinds them to death.
Fix: replace motor - new bearings will come with the new motor.
Alternate Fix: replace dishwasher. Often new motors are so expensive, replacing the whole unit is the bast option, especially with Sears/Kenmore (where parts are expensive)
Try: www.SearsPartsDirect.com.
I tried the sears parts web site for you, but you model number came back to a Bissel carpet cleaner.
Posted on Oct 15, 2010
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Dec 12, 2015 | Kenmore Dishwashers
Our Kenmore Dishwasher Model #16532 is not drying our dishes anymore. It is 8 years old. Could the heating element be worn out?
Entirely possible. If you have a multi meter you can do a continuity test on it, that is how you spot a burnt out element on a water heater. Just turn off power at the breaker panel first. just having it switched off at the unit is not enough
Jun 11, 2011 | Kenmore Dishwashers
8 year old dishwasher has increasing gotten more noisy during wash cycle.
change te winding of the mortar or change the mortar or clean the whole dish
Apr 23, 2011 | Dishwashers
The soap dispenser won't open during the cycle on my 15782 model Kenmore Dishwasher. I am using gel pack soap...so I do not have old soap caked in the receptical. Any thoughts?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Oct 26, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
Kenmore 665.16532201 dishwasher runs through cycles normally, but makes a loud metallic and buzzing noise when in the wash cycle. It sounds like a pump is burning out. What is wrong? Thank you, Eric
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 11, 2010 | Kenmore 24 in. 16532 - Multiple Color...
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
Dishwasher stopped at end of cycle and won't drain
Check the drain pump, usualy accessable from the front bottom through a hatch, clear out any **** from there and try again.
Sep 27, 2009 | Kenmore 24 in. 16532 - Multiple Color...
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore Elite ultra wash dishwasher
When it is off, reach down around the base of the spray assy and run your fingers around the entire circular base where junk can get caught. I've found broken glass and plastic utensils. Why do some of us wash disposable utensils? Huh? You may find something like a piece of plastic, glass, or the like that is making the noise. Be careful not to cut yourself.
If this buzzying sound is not coming from the tub, and is actually below the tub and in front right side, it is most likely the electrical relay switch ( which can make that sound when it is straining or failing).
Oct 07, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Water leak
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Aug 21, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher Logo
169 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
