Question about Linksys Wireless-G WRT54G Router
Linksys I tried the 192.168.1.1 and it still tells me the oporation is timed out. Not sure what steps I should follow next. Thanks for the help.
You are probably not on the same network as your router addr.
1, Click start/run then enter "cmd" (no quotes) to open a command window.
2, type in "ipconfig /release" (no quotes)
3, Close the command window
4, Click on start/run and enter "http://192.168.1.1" (no quotes), this should open up the login page for your linksys router.
5, Enter the user name and password for your router (for linksys, it's admin/admin)
6, Configure your router with info from your ISP.
At this point, you need to write down the address you configure for the router (eg 192.168.20.100), You also need to note your user name and password, also you should only leave one DHCP server on. The new address you configure for your router will become your gateway address.
7, After all changes, save and exit the router configuration page. Close your browser.
8, Repeat steps 1 to 3 above, then reboot your computer.
This should put all your equipments on thesame network - (ie 192.168.20.xxx for the example above)
If all is well, you should be able to connect to the internet.
send me an email me if you need further help at
grandpaid-email@yahoo.ca
I dont frequent this site. hope this help
Grandpa ID
Posted on Jun 04, 2008
Our wireless code isn't letting us log on
May suggest you RESET your router to factory default settings
Here is the web site: http://homesupport.cisco.com/en-us/wireless/linksys
The web site above gives you step by step
Once you follow the steps to RESET, and build your network, you can make sure each device works before going to next step.
Apr 01, 2011 | Linksys Wireless-G WRT54G Router
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Linksys will not connect correctly to my laptop
Try a new setup.
On your computer, insert the supplied Setup CD that came with your Router. Setup should start automatically.
NOTE: If setup doesn't load automatically, please click here.
The first screen greets you with the Software End User License Agreement. Please take a moment to read through and understand the agreement. Once you're ready, go ahead and click Next.
NOTE: The Linksys Wireless-N Router model displayed on the setup screen may vary based on the Linksys Wireless-N Router model you have.
Step 4:
On the next window, please follow the on-screen instructions on how to connect your Linksys Wireless-N Router:
kb21463-002_en.png Plug one end of the power cable into your router and the other end into an electrical outlet.
NOTE: The Linksys E3000 features a power switch, located at the back-end of the unit, next to the power port. Please make sure that this switch is ON. Other Router models may not have this feature.
kb21463-004_en.png Plug the Internet cable into the yellow port in the back of your router labeled "Internet". Plug the other end into the modem.
QUICK TIP: Click Show me how for an illustrated guide on how to complete the above instructions.
After completing the above steps, click Next to continue.
Step 5:
Setup will now perform a series of tests to determine the optimum configurations for your network. You may notice your computer connecting and disconnecting to a wireless network several times. This is normal. Your wireless network is simply being secured.
NOTE: The setup process automatically generates a unique and secure Wireless Network Name (SSID) for your convenience.
kb21463-006_en.png Step 6:
The next part of the setup automatically detects your Internet connection type. If you are using a DSL connection, you may be requested to enter your account details. If this is the case, simply enter your Account name and Password in the allocated fields. Otherwise, you may skip ahead to Step 7.
NOTE: If you don't know your Account name and Password, your Internet Service Provider (ISP) will be able to provide these details.
QUICK TIP: Click Examples to see what your Account name should look like.
kb21463-007_en.png NOTE: Cable Internet users will not see the above screen.
Step 7:
Sit back and wait a moment as setup finalizes your Linksys Wireless-N Router settings, and re-establishes your Internet connection.
kb21463-008_en.png Step 8:
Once your Internet connection is up and running, a confirmation window similar to the screenshot below will appear on your screen. Your Linksys Wireless-N Router is now secure and connected to the Internet. This concludes the setup process. Click OK to continue.
Step 9:
You will now be taken to the main Cisco Connect window which lets you manage and further personalize your network settings. If you would like to learn more about the available features in Cisco Connect, please click here. Otherwise, you may click on the Close button to exit Cisco Connect, and begin surfing the Internet right away.
NOTE: To launch Cisco Connect again at later time, on a Windows computer, go to Start>All Programs>Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For more help on this, please click here.
kb21463-010_en.png NOTE: Cisco Connect is automatically installed each time you use the Setup CD or Easy Setup Key to setup or connect to your Linksys Wireless-N Router.
Nov 02, 2010 | Linksys Wireless-G WRT54G Router
How to configure my router to ADSL2 modem router
print2.gif print email2.gif email
Title: Setting up your Linksys Router for the first time Article ID: 21463
Your Linksys Wireless-N Router comes with the Cisco Connect software which makes setting up and managing your Linksys Wireless-N Router a quick and simple experience. You'll have your Linksys Wireless-N Router up and running in no time.
NOTE: The Linksys E2100L router is only available in the U.S. For help on setting up a Valet or Valet Plus, please click here.
Some basic requirements before you begin
i. An active Internet connection.
ii. A computer with a wireless or wired Ethernet adapter, running one of the operating systems below.
- Windows XP with Service Pack 3
- Windows Vista with Service Pack 1 or better
- Windows 7
- Mac OS X Tiger 10.4.9
- Mac OS X Tiger 10.4.11
- Mac OS X Leopard 10.5.8
- Mac OS X Snow Leopard 10.6.1
Getting started
Provided that the above requirements are met, you can now begin setting up your Linksys Wireless-N Router. In this example, we'll be setting up the Linksys E3000 High Performance Wireless-N Router. The following steps will walk you through the entire process.
Step 1:
Your Linksys Wireless-N Router allows you the freedom of running setup via a wired or wireless connection. Therefore, please start by performing the instructions under the description that best matches the computer you're working with. Proceed to Step 2 once you're done.
Description A:
You are using a computer with no wireless connectivity that is normally connected with an Ethernet cable to your DSL/Cable modem.
Instructions A:
Please connect one end of the supplied Ethernet cable into the Ethernet port on your computer, and connect the other end into one of the numbered Ethernet ports at the back of your Linksys Wireless-N Router.
Description B:
You are using a laptop with a built-in wireless adapter.
Instructions B:
If you're using a laptop, please ensure that its wireless feature is switched ON, and that your laptop is positioned within 5 feet of your Linksys Wireless-N Router.
NOTE: Most laptops have a switch that turns its wireless feature ON and OFF. Refer to your laptop's documentation or online help if you're unsure where this switch is. This doesn't apply if you purchased an external wireless adapter separately.
Step 2:
Step 3:
Step 4:
Step 5:
Step 7:
Step 9:
Oct 16, 2010 | Linksys Wireless-G WRT54G Router
I can't reach my ip to change my lan config
yeahlife,
The default IP Address for Linksys routers is 192.168.1.1. You may want to try accessing your router's configuration by typing this IP Address in your browser.
If you have any additional troubles, please let me know.
Regards,
moriarti5
Jun 02, 2008 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Firmware
Here's the Linksys step-by-step guide for your router:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3686&lid=5531661879B01
Are you connected to the wireless router with an ethernet cable? Generally, you want to hook it up this way first so you can configure it. If you are hooked up with a cable open your web browser and type in the following address: 192.168.1.1 this should get you to the router's web page. The default login for linksys is username: blank, password: admin
See if you can connect to the router in this way. If you can then we can go through the next steps or you can try using the above link.
Good luck.
Dec 19, 2007 | Linksys Wireless-G WRT54GS Router...
CANNOT MAKE NOTEBOOK WIRELESS WITH THE ROUTRE
Hi my name is Cameron I'll tak care of you (:
1.Next time do not use caps lock.
2.Use better grammar next time. I use Spell checker in FF.
Alright, first your router does not make the laptop wireless, the wireless card inside your laptop makes its wireless. Secondly if you do not have a wireless card you need a "Wireless USB Adapter" google that.
Thirdly, tell me what your doing in steps. For example:
Step 1-I go to search for wireless networks
Step 2- I try to connect to my network.
Please try saying it in steps so we all can understand where your getting the error, and how to fix it.
Thanks,
Cam
Oct 19, 2007 | Linksys Wireless-G WRT54G Router
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
