Question about Kenmore Refrigerators
This unit contains a 9020 water filter. Can you remove and still use the ice maker and water dispenser?
    Sergeant:
    Champion:
  • 226 Answers
No you cannot use
Posted on Oct 15, 2010
I put a new filter in my fridaire, but water dispenser not working, and ice maker not working
repairs should be performed by a qualified repair person. when replacing a filter make sure the filter properly installed. once secured get 3,1 gallon containers to purge the water line and reservoir. BEWARE! water may continue to run while flushing the water line. this is why you'll need 3 containers. once you are able to finish flushing the line and the water is no longer gray the flushing for the water dispenser is complete. dispose the ice in the container in the freezer. let the ice maker cycle a few hours then dispose the filtered ice. once copleted you're done.
Jun 04, 2017 | Refrigerators
Why won't the water come out of the in-door water dispenser? Why won't my ice maker make ice?
Be thoughtful of any water leaks. Water leaking beneath the machine will damage floors.
If both the ice maker and water dispenser are not working it is likely the feed connection from the wall to the unit. The hose/ copper tube can get kinked or the valve at the connection at the wall internally plugged. Close off the water at the wall and using a catch remove the connection at the unit open the valve at the wall and confirm the that water flows freely through.
Check the filter of the water located usually at the front grill near the floor. If the filter is removed the water connection will buipass the filter.
It is not likely with both the ice maker and water dispensor that both electrical solenoid valves have failed.
26159659-bocfglvi4lojepqiax35xhd0-1-5.jpg Hope this helps?
Apr 10, 2016 | Kenmore Refrigerators
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Not enought water to ice maker
Can you provide a make & model # for the unit?
Feb 08, 2014 | Refrigerators
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser and ice maker don't work
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Apr 30, 2017 | Whirlpool GS6NBEXR Side by Side...
Our icemaker cannot make ice so we were using small ice in the ice dispenser. Now the ice dispenser does not work. When we first started having trouble with the ice maker we immediately changed the...
Both of those are controlled by a voltage signal sent to the back and rear near floor of the back of your refrigerator. The part is a water control valve. When you press the dispense water button the valve if not defective will open and allow water to travel through the bottom fresh food section water reservoir to the cup. When the ice maker dumps fresh cubes to the tray to store foe dispensing ice it also opens the valve for its side fore just enough time to refill the ice maker. Then the ice maker waits until it senses frozen ice and begins the cycle by heating elements below it to loosen the cubes to begin the cycle again. So get someone to unplug the side on pack and put the probes of a multimeter into each female side and press dispense, you should see 120 volts there. If not the dual water control valve needs replaced. Part Number 4389177
Sea Breeze
Jul 15, 2009 | Refrigerators
Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Apr 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
