Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher..water coming out the vent up out of the sink
Water coming out of the vent tube..on top of the sink
  • 868 Answers
Pull the hose off your disposal and poke something in the disposal to make sure its not clogged,by the way it is clogged.Look into the hose and clean it out .***NOTE***: If you cant poke something through the disposal opening,than the plug is still inside and would have to be hammered out with a chisel/screwdriver or ice pick.
Posted on Jun 03, 2008
CHH50 Dishwasher getting back flow through the rinse tubing and the filling container when machine is switched off
Most dishwashers require a DRAIN VENT between the drain hose and the connection to your drain plumbing. If there is no drain vent, water from your sink drain can easily flow into the dishwasher. If you do not have a drain vent, install one. If you have one, make sure that the vent hole is not obstructed in any way.
May 11, 2015 | Dishwashers
I get water all over my counter when dishwasher gets rid of water. There is a feature on my sink of which water comes out. This just started...
Since this just started, I would suggest cleaning out the p-trap under your sink. If your sink drains sluggishly without a pump, then your dishwasher will overflow your drain pipes with its pump.
Also, try facing any air gap opening into the sink.
If the pipes are clear, you may need to add a length of pipe between the air gap on the sink and the 'y' connector that the drain lines are connected to. This will help keep any splashing water from 'climbing' out of the sink-top vent. Good luck
Dec 04, 2009 | Dishwashers
I INSTALLED A VENT IN MY SINKTOP FOR THE WASHER AND WHEN IT DISCHARGES THE WATER IT COMES OUT THE VENT AND RUNS INTO THE SINK.
Installed vent? Dishwashers drain directly into the sink drain line. Drain can be installed in cross over between sink drains or on line from sink drain.
Jun 22, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
Water from dishwasher flows into sink and not into garbage disposal ???
there is a clog between your garbage disposal and the vent (the part water is coming out of) .most likely the clog is where it goes into your garbage disposal
Apr 23, 2009 | Dishwashers
Water refilling after dishwasher is cycled off
Leave the D/W door open and make sure the water is not coming from the water inlet .
It may be oozing up from the bottom when you run water in the kitchen sink.
Does your dishwasher vent through a counter top Y siphon. It could be clogged causing water to re-enter the D/W.
Feb 10, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher leaks at top of sink
hi some old dishwasherhas that y ,,,,,,the y is there so when washer drains it does not go bact to the machine,,,,,,,,some times the pipe that goes from y to disposer gets clugged and you can turn the hole tourd the sink the drain into sink
Jan 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Jan 21, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Dishwasher draining into kitchen sink!
Is the water coming out the holes of the airgap "vent". If so, you have an obstruction from the hose that goes from the "vent" to the garbage disposer and is causing the drain water to back up. __________________
Jan 12, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Water comes out through our air gap (vent)
You are going to have to clean the air gap or replace it. also check your drain to insure it's not clogged if it's clear again replace the air gap
Jan 06, 2009 | Dishwashers
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
132 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
