Question about Canon PowerShot A590 IS Digital Camera
When I turn the camera on I receive a 'lens error, restart camera' message. Restarting does nothing to help the lens out. Please Help!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 15, 2010
I have an IXY 110. how do i restart the camera?
I'm guessing that you're asking because your receiving a "lens error, restart camera" message. Unfortunately, restarting the camera (turning it off and back on again) rarely corrects the problem. Many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 13, 2011 | Canon Cameras
Canon SD770 IS's lens won't close. I get error message: Lens error, restart camera. Restarting doesn't work. Any advice? Strange that it won't even take photos or playback while the lens is stuck!
Welcome to FixYa
Camera detected this error while moving the lens and cut the power automatically. This error message may appear if you press on the lens while its moving. Make sure that when your going to turn on the camera, your hand or fingers will not block the lens to retrack. Turning on the camera in a dusty or sandy environnment is also one reason for this message to be displayed.
Try to remove the battery and re-insert it, then turn on the camera again. If the message still persist, take the camera to a service center because there may be a problem with the lens.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa
Apr 15, 2011 | Cameras
My FINEPIX S1000fd fujifilm camera ZOOM ERROR
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
May 27, 2009 | Fuji FinePix S1000FD Digital Camera
Lens will not retract and camera will not work
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Dec 08, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Canon digital IXUS 60. Lens does not move in and out. Camera turns on but nothing happens. Unable to take photographs. Error message:- Lens error restart camera. Restarting camera does not resolve problem
I'm guessing that the lens is stuck. Either the cover refuses to open because something is wedged in or a mechanical malfunction. The camera won't work if the lens does not come out a bit. Take a look at the lens and examine why the cover doesn't open up. If it is a mechanical malfunction (meaning internal problem), might as well have it fixed. Be careful and keep your fingers off the lens. You may touch the cover but hands off the lens. Hope this helps.
Jul 17, 2008 | Cameras
Please help
I get that exact problem, too. I keep on restarting it and it gets the same message. It said in my manual that is it repeats that message, you should contact your Canon Fixer person.
Mar 11, 2008 | Nikon COOLPIX L10 Digital Camera
Help please
I'm assuming you have a lens error which is giving you the restart message.
It is kind of misleading, but to restart the camera means to power cycle the camera or remove and reinsert the battery.
If you do have a lens error, if restarting the camera doesn't work, you'll need to get the lens fixed if to remove the error.
Dec 17, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShor S3 not functioning
Had my S2 IS now for 3 years , never had a problem with the lens. I'm careful not to bump my lens into anything. I actually bought the lens hood and put a filter on my lens so that no dirt can get into my lens or I can't accidentally bump my lens into anything while i'm using it as it's protected by the adapter and filter.
Dec 08, 2007 | Canon PowerShot S3 IS Digital Camera
Canon powershot sd900
I have the same problem, but i didnt drop mind. The lens where out when i put on da pack and now it won't start.
Apr 09, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot A590 IS Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
