Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
The tb475ss trimmer will not start. - Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
    President:
  • Troy Master
  • 1,545 Answers
It is difficult to diagnose a no start problem without the machine being on hand. You need to check for blue spark, fresh oil and fuel and a clean air filter. You also need to verify that the engine isn't worn out and that it has compression. To try and get it to start, remove the air filter and squirt some aerosol type carburetor/choke cleaner into the opening to the carburetor. If it runs a few seconds, that is good and eliminates some of the causes. It may just need a good carburetor cleaning. Post back with results.
Posted on Oct 16, 2010
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas comes out of top of gas tank on Troy Bilt TB475ss Trimmer
Fuel lines are needing replacing as they have shrunk and no longer sealing.
Jun 19, 2015 | Troy Garden
I have a Troy Bilt 4 cycle trimmer, TB475SS. The small fuel line in the gas tank has come off. I is about 6" long with a filter at the end. The trimmer can not **** any gas. How can I reattach it...
i would suggest to change all you fuel lines. troybilt uses specific fuel lines that they sell. you cant use your regular tygon fuel lines.
Sep 23, 2011 | Troy Garden
Pull starter
easiest thing is to take it off machine-that is the housing holding the string/handle-usually 4 screws-very easy(they may be allen wrench screws)and take it to a local lawn place and ask them if they rebuild them or if its cheaper to maybe just buy/order the entire thing if they have it/can order.It would probably cost 20.00 tops for the new housing with string and handle ready to go.Hope this helps
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
Whats the valves set at on a tb475ss weed eater
exaust is set to .013 to .016,,,,,,
intake is set to .oo3 to .006......
i hope this does the job for you,,,good luck
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troybilt 4 cycle trimmer (TB475ss) won't start. New tank, new plug, new gas??? Will occasionally start, run for about 10-15 secs, then stops. Won't restart. Help!
Take the plastic cover off that covers the muffler and cylinder head. I've had 2 cylinder heads crack. The trimmer still ran but had little to no power and would not throttle up. First head cracked at the head bolts. The second one cracked above the bolts. The side that has the carb and fuel tank is harder to see and you must remove the carb and fuel tank to check. Also I've read online that this trimmer has a problem with the fuel line cracking at the bulb and in the tank.
Sep 12, 2009 | Garden
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
262 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
